First post, by cyberluke
Hi, I tried both CD-Man 1.0 and 2.0 on 386 and 486. Each time, I finish the level, it restarts level 1 instead of progressing to level 2. Tried various versions. Score will continue to add, just cannot get past that level 1. I remember there is level 2 in the ses with sharks.
Is it working for you?
Reply 1 of 3, by zirkoni
1.0: You need to finish the same level 3 times before the game advances to the next level.
2.0: You need to finish the same level twice. After finishing all levels twice the game goes back to level 1, this time you need to finish each level only once. The last last level cannot be finished, the pellets won't disappear after eating them.
https://youtube.com/@zirkoni42
Reply 2 of 3, by cyberluke
Ah, really? That sounds like a bug, right? Thank you for info. I think this will be a job for Action Replay card. Freeze memory and look for this variable to increase it manually.
Reply 3 of 3, by zirkoni
No, it's not a bug. In the high score table you can see the game differentiates these as screens and levels.
