First post, by millenium
Hi everybody,
I have a dos version of this game and I can't run it. I tried VDMsound (
some posts say that it should run this game ), but it doesn't work and displays me "Failed to load sound drivers". What does that mean and what should I do to run this game ?
P.S. I tried SCUMMVM and the game worked, but without music... That's
not good enough...
Reply 1 of 7, by Nicht Sehr Gut
Originally posted by millenium I have a dos version of this game and I can't run it. I tried VDMsound (
some posts say that it should run this game ), but it doesn't work and displays me "Failed to load sound drivers". What does that mean...
Have you run the install/setup program to configure the game for SoundBlaster audio yet?
Well they're still at 80% compatibility, so that's to be expected. BTW, have you tried using the Windows version yet? IIRC, Simon2 had both DOS and Windows executables.
Reply 2 of 7, by millenium
Yes, and it didn't help.
Somehow there's no win executable... Any suggestions ?
Reply 3 of 7, by Nicht Sehr Gut
Originally posted by millenium Yes, and it didn't help.
You tried both General MIDI and Adlib/SoundBlaster for the music?
If you still can't get it running, you may be stuck. I'm certain the CD-version has the Windows 95 executable. Not sure about the floppy version.
Reply 4 of 7, by bgbennyboy
Did you try all the simon 2 targets with ScummVM?
Theres the:
Simon2Dos - dos floppy
Simon2Win - win cd
Simon2talkie - dos cd
Also theres the XP patch on adventuresoft's site here
Reply 5 of 7, by Nicht Sehr Gut
Originally posted by bgbennyboy Also theres the XP patch on adventuresoft's site
Already covered... it's only good for the Win95 executable, which he doesn't have.
Reply 6 of 7, by millenium
Yes. It didn't help.
Yes, I have...
What's strange this game doesn't even run in DOS 6.22, which I still have, because of that "can't load sound...". Let's say my package is completetely wrong... Why does it run in SCUMMVM ( DOS talkie ) with
full voice, but without music when ?
Reply 7 of 7, by Nicht Sehr Gut
Originally posted by millenium Yes. It didn't help.
Then something's up, because I know it can work using the FM music option (AdLib/SoundBlaster).
That's what it sounds like from what you described.
ScummVM is basically replacing the game engine with it's own and using the game's data files. It could be that you're missing critical pieces of the game's "engine".
