Reply 20 of 22, by gerwin
- l33t
Kordanor wrote on 2024-01-31, 18:12:But the issue is, that the new setsound.exe does not update the sound.cfg of the game. So when I start the game, it will still use whatever was saved there. I guess it will use the other new files now. But unfortunately it makes no difference in how it sounds. That is true for both setups.
You got any suggestion here on what I did wrong?
Can you revert the files back to the original versions, then only update the two SoundBlaster DIG files with the newer ones supplied here?
