First post, by retro games 100
If I run an old game (say Duke Nukem 3D in DOS, at 800x600 Vesa mode), the display is skewed to the right -- so I have a blank/black 1 inch column on the left side of the screen, and I lose 1 inch of the "action" on the right side of the screen.
I've tested 2 Matrox cards on 2 LCD displays, and I get this same problem on all 4 tests. (I also get this problem if I select 640x480 in the particular DOS game's screen setup section.)
Please can someone offer up some clues as to what is happening, and also if there's something that I can do to remedy the situation.
Thanks a lot! Best regards from Robert.
Reply 2 of 2, by retro games 100
Thanks.
I used the silly fiddly LCD buttons and selected a display option called "auto", and magically the screen centred itself!
Thanks a lot, best regards from Robert.
