First post, by dbailey
I am trying to get a diagnostic tool written for DOS to talk to a NIC chip resident in a PCI slot. (Obviously
If I boot the machine using FreeDOS, The utility recgnizes the card and all is fine. If I run the same utility under DOSBOX (0.73), it never recognizes the card.
I compiled DOSBOX with --enable-debug active. When I run the program I get the following:
122487514: BIOS:INT1A:PCI bios call 2
122487522: BIOS:INT1A:PCI bios call 2
122487530: BIOS:INT1A:PCI bios call 2
122487538: BIOS:INT1A:PCI bios call 2
122487546: BIOS:INT1A:PCI bios call 2
122487556: FILES:file open command 0 file autoexec.do
Is there something I am missing in my configuration? Are there problems if the card tries to directly access the memory of the PCI device that dosbox does not support?
Thanks
Doug Bailey
