First post, by EdenShock
Hi all, I found my old Creature Shock disc along with a few others (DIG and Lost Eden) and I am trying to install and play Creature Shock. The problem I am having so far is running it in Dosbox 0.74, dosbox immediately says "Message: Can't find Creature Shock file".
I wanted to start this thread to hopeuflly document me fixing this from start to finish incase anyone else runs into the same issue.
I installed the game from the disc and mounted it onto the "a:" drive in dosbox.
so my first question is what does this message mean and how can I fix it?!
Thanks for any help.
Reply 1 of 11, by leileilol
try mounting it on the D: drive instead, cd-rom drives work best being the 'next letter'. A: is for floppies.
FUCK "AI"
Reply 2 of 11, by EdenShock
On my system I have C: (with windows installed on), D: (harddrive partition) and E: (CD Drive). i tried mounting the creatureshock drive to F: but receive the same message.
Thanks for the suggestion. 😀
Reply 3 of 11, by Jorpho
Programs running in DOSBox don't care what your hard drive partitions are. There should not be any problem if you use "mount d E:" in DOSBox.
Reply 4 of 11, by EdenShock
I get the same message again. Could I have not installed it correctly? If I try to install it from dosbox nothing happens, if I install it from disc the normal way it installs but I get the above message when I try to run it through dosbox. 😐 🙁
Reply 5 of 11, by Jorpho
You're going to have to go into more detail regarding exactly what you are typing in DOSBox when you try to install the game.
Reply 6 of 11, by EdenShock
I've completely removed all references to Creature Shock and decided to start again from scratch.
With cd1 in the drive I opened dosbox and mounted the cd using "mount d: e:\ -t cdrom"
Then I switch to d: and type "install". This opens the CreatureShock installation program. Everything looks good and the sounds all work when tested, I hit Install and I now receive a new message
"An error occurred while creating C:\CRSHOCK Please delete the game and re-install"
Reply 7 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
mount a C drive as well (so 2 mounts)
Water flows down the stream
Reply 8 of 11, by EdenShock
thanks for the reply. I tried that and now after I hit install it just closes the creatureshock install program and does nothing.
I've tried a few different approaches and have got the game to load but it now crashes when I attempt to play the first mission. What I did to get this far was this...
I copied both cd's to a c:\Dosbox\CRSHOCK, then installed (from disc) to default c:\CRSHOCK. I then copied these new files into the c:\Dosbox\CRSHOCK folder (overwriting when prompted). Then in dosbox I mount c: as usual and then the dosbox\crshock folder as d:, then change to d: and type Shock to load the game. I created a batch file that does all this and makes it more clear.
//batch file
cd..
cd..
cd..
cd dosbox
dosbox -c "mount c c:\dosbox" -c "mount D C:\dosbox\crshock" -c "d:" -c "shock"
Reply 9 of 11, by EdenShock
I read somewhere that to fix this problem the cycles in dosbox need changing to 40000. I followed that advice and it now works! I havn't got past level 1 yet so I can't say for sure if it all runs now. I updated the batch file to make this change.
//batch file
cd..
cd..
cd..
cd..
cd dosbox
dosbox -c "cycles 40000" -c "mount c c:\dosbox" -c "mount D C:\dosbox\crshock" -c "d:" -c "shock"
Reply 10 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
"mount c c:\dosbox"
Reply 11 of 11, by Davros
thats a lot of cd..'s
