First post, by brotherlu
HI guys , noob here
And i need help running Sherlock Holmes Consulting Detective
Tried VDMsound with launchpad, Can't detect Sound card
Tried DOSBOX 0.60, same
Tried screaming at it, didn't do a thing.
Help me if I left anything out
PIII 1.0 Ghz
80Gb HD
Sound Blaster 5.1
Radeon 7500 Retail
392 MB Memory
Reply 1 of 10, by brotherlu
sorry, forgot to add , i am running windows 2000 (SP4)
AlleyCat ROCKS,
Thats Playabilty !!!
Reply 2 of 10, by eL_PuSHeR
Did you launch the game directly? Maybe you forgot to set up sound first. Check for setsound.exe or sound.exe or setup.exe or similar.
Reply 3 of 10, by brotherlu
There is no file like that, the only executable file is sh2.exe.
According to the readme file. the error i get means it can't detect a supported sound card. Even when using VDMSound.
I think there is a specific configuration for VDMSound i need to make the program run.😕
AlleyCat ROCKS,
Reply 4 of 10, by eL_PuSHeR
In a nutshell: AUTODETECTION is evil. Try using a fairly standard SB values -> A220 I7 D1 - Then keep changing the IRQ maybe to 5 or 10 to see if there is luck.
Reply 5 of 10, by brotherlu
Just tried it,
In VDMSound and DosBOX 0.60 both i set the config for all ranges still no go.
Darn, this thing. I wouldn't mind playing the game without sound except I don't have that option.
There is no option for no sound.
Darn it😕
AlleyCat ROCKS,
Reply 6 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
in dosbox you can disable the soundblaster by setting sblaster=false
Water flows down the stream
Reply 7 of 10, by brotherlu
I meant the game doesn't have any option for no sound, so even i type blaster=false it still won't because it will stil give me the same message always.
The message i attached,
cheers for your help guys
AlleyCat ROCKS,
Reply 8 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
sblaster=false should be in the configfile of dosbox.
Reply 9 of 10, by Snover
Qbix. Read what the man's saying. The game will NOT RUN without a soundcard.
Yes, it’s my fault.
Reply 10 of 10, by brotherlu
Thanks Snover for emphasising my problem, i should have wrote it clearer maybe.
And thanks Qbix for the info, i will keep it in mind when i will need it next time.
still need a mircle though
Cheers folks
AlleyCat ROCKS,
