Bad hardware?
First post, by dforell
I've recently got some parts together for a win98/dos gaming machine.
I've been having some trouble with several games I have installed.
Dungeon Master 2 tells me to run the setup program, even if I already have.
Corridor 7 crashes at a memory page related loading message.
Dungeon Keeper runs, but when I quit, it mentions a problem accessing controls.dat.
Chasm mentions a corrupt header on csm.bin.
Probably more, haven't tested them all on this machine.
I've tested all these games and they run just fine in dosbox.
I've tried a pure win98 setup using restart in dos mode and I'm now using a FreeDOS 1.1/Win98 setup.
Specs:
Abit BE6 II motherboard.
Pentium III 800mhz
MSI Nvidia GeForce 4 TI4200 64M
SoundBlaster 16 Value
ADMtek NC100 Ethernet
Could this be a bad hard drive? Is the motherboard subtley bad?
Maybe a bios setting?
Reply 1 of 29, by Davros
have you tried any hdd diagnostic software ?
Reply 2 of 29, by batracio
dforell wrote:
Specs: Abit BE6 II motherboard. Pentium III 800mhz MSI Nvidia GeForce 4 TI4200 64M SoundBlaster 16 Value ADMtek NC100 Ethernet […]
Specs:
Pentium III 800mhz
My bet is bad caps.
Reply 3 of 29, by dforell
bad caps?
I find it odd that win98 and freedos run flawlessly.
Some dos games seem to run okay too.
Reply 4 of 29, by batracio
http://en.wikipedia.org/wiki/Capacitor_plague
Looking for bad caps should be one of the first things to do when you find an unstable system built around a motherboard made circa 1999-2000. Of course, there are other possible issues that may cause the same symptoms (bad ram, power supply fault, hard disk fail), but bad caps were somewhat common those days, and very easy to identify just by looking at your board:
http://www.badcaps.net/store/images/000_1065.JPG (good caps)
http://www.sanslogic.co.uk/images/abit-be6-ii … capacitors.jpeg (bad caps)
Please check whether you have any capacitor looking like these ones or not, so we can at least discard that possible issue.
Reply 5 of 29, by dforell
Damn, several appear "bloated" and one looks to be "leaking".
Reply 6 of 29, by batracio
Sorry to read that. If you are handy with the soldering iron, you can buy a replacement kit and recap the motherboard by yourself:
http://www.badcaps.net/store/product_info.php … &products_id=18
Alternatively, you can buy another 440BX motherboard for a little more (including shipping):
http://www.ebay.com/itm/ws/ebayISAPI.dll?View … em=221036955198
http://www.ebay.com/itm/ws/ebayISAPI.dll?View … em=140717239758
Reply 7 of 29, by dforell
Thank you very much Batracio. I did some soldering in an electronics class in highschool... it wasn't very good work.
Reply 8 of 29, by PhaytalError
See if anyone in your area can solder them in for you, most people will charge a very fare fee, just supply them the new caps and they will have them soldered in in less than 20 minutes. 😀
Also as batracio pointed out you could always get another motherboard on eBay or Amazon... the ASUS P3B-F v1.04 is an AMAZING Slot-1 motherboard and will support Pentium III up to 1.4Ghz with the latest BIOS, and a slotket. It's the best 440BX based motherboard i've ever used, and supports "undocumented" 133Mhz FSB, so PC-133 RAM and 133Mhz FSB CPU's will work perfectly in it as well. 😀
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
Reply 9 of 29, by dforell
The ASUS P3B-F is a slot 1 motherboard and I can't seem to find any slot 1 Pentium iii processors over 1 GHz. Is this correct?
Reply 10 of 29, by Sune Salminen
That's correct, you need a "slotket adapter" to use a socket 370 Pentium III.
I used to use this one with a 600Mhz PIII in my ASUS P2B:
http://www.frostytech.com/articleview.cfm?articleID=175
Reply 11 of 29, by dforell
Wow, you guys have been amazingly helpful/knowledgeable. It will be great to upgrade to a 1.4 GHz processor. Now I need to get rid of this old processor and memory.
Reply 12 of 29, by batracio
Don't get rid of CPU and RAM yet. A P-III 800 is more than enough for every DOS and most Win9x games. If you just replace the motherboard, everything else will keep working fine. Also bear in mind that not every slocket adapter will support a Tualatin core (P-III CPUs over 1 GHz). You would need a Powerleap PL-IP3/T (very expensive and hard to find), an Upgradeware Slot-T (it once was cheaper and easier to find, now getting scarce too), or a pin-modded Tualatin (there was a seller who used to list tons of these already modded CPUs at ebay, but I cannot find him anymore). My advice is to replace only the motherboard for the moment, and later upgrade step by step.
Reply 13 of 29, by PhaytalError
A Powerleap PL-IP3/T is NOT required for the ASUS P3B-F motherboard.
The MSI MS-6905 Master slotket adapter works just fine and those are as cheap as $11.99 USD and sometimes cheaper. The Asus S370-DL slotket adapter also works, however the MSI MS-6905 Master is the most common.
A simple mod to the slotket is all that is needed, and you'll have a working Pentium III 1.4Ghz Tualatin system.
How-To Guide: Tualatin in the Asus P3B-F
Modded BIOS: Asus P3B-F BIOS 1008 Beta 004 with all Microcode Updates
until CPUID 06B4.
Reply 14 of 29, by batracio
I know that Asus P3B-F can provide 1.45-1.5V for Vcore and therefore it doesn't require a Powerleap PL-IP3/T. That's why I mentioned other options. And yes, there's a fourth option I didn't mention, making the pin-mod by yourself. But come on, dforell isn't confident enough of his soldering skills in order to recap his motherboard, so I wouldn't recommend him to make the pin-mod by himself, which I think is a more complex task. However, it would certainly be the best option for people who like challenges 😀
Reply 15 of 29, by dforell
Just an update on purchases.
ASUS P3B-F Pentium III ATX Intel 440BX Motherboard
ASUS S370 Slot 1 to Socket 370 PGA370 1.8-2.6V Adapter
Tualatin Pentium III-S 1.4 GHz P3-S 1400 SL657
Low Density PC133 168Pin Memory
I might still see if I can get the old motherboard's caps fixed.
Wouldn't hurt to keep the old parts around for backup.
Reply 16 of 29, by PhaytalError
dforell wrote:
Just an update on purchases. […]
Just follow that guide I posted and install that BIOS and you'll be golden! Have fun and enjoy your awsome new Pentium III system! 😁
Please note: You should use Aflash utility, rev. 1.24 to flash the BIOS or else you may end up with a "Error: data compare failure" message after flashing the BIOS.
Reply 17 of 29, by Jorpho
Gee, I guess this means the only thing the 81x chipset has over the 440BX is the support for AGP 4X instead of 2X. Interesting.
(Of course, the real advantage would be in maxing out the RAM to 1 GB, and finding four 256 MB SDRAM modules might be a bit tricky.)
Reply 18 of 29, by gerwin
440BX is missing the proper AGP clock divider at 133MHz FSB, therefor it is never 'officially' supported.
Reply 19 of 29, by Imperious
It's hardly surprising Abit have bit the dust, I think most if not all Motherboards they made in that era have cheap rubbish capacitors on them.
I have replaced the caps on my KT7-RAID a couple of times, different caps of course
A free bit of advice, Don't ever throw any old hardware out, unless it's stuffed of course.
Dial-up modems throw out, they're the exceptions in my opinion.
I've got 5 processors for my motherboard, glad I kept em.
