Reply 20 of 47, by Nicht Sehr Gut
- l33t
So the drivers you just downloaded are WDM? To be absolutely sure DOS isn't available, launch the setup.exe file to start Live!Ware installation, now go to the point where it shows what components will be installed. Now press alt+escape and run explorer. Go to Temp folder of windows, (Default is c:\windows\temp) Inside is a lw3 folder. Copy the audio.ini inside to your desktop or any easy-to-find location. Use notepad to open, then find the line "DOS=" line.
If it's there:
0=Don't install DOS drivers
1=Do
