Normality
First post, by CrimsonStar
Hey, I'm relieved to see that there usually is a way to get all those old classics working even on the most powerful of systems. I'm currently using:
AMD Athlon XP1800+
Soundblaster Live! 5.1
Radeon 9800 Pro 128mb
512MB RAM
120*2 GB HD
and Windows XP Pro
I want to play Normality, as I've never got around completing it. But I can't seem to get it working properly, and I've not seen any posts or topics regarding Normality. When I use DOSbox (where I'm a beginner) I can't get the game working smoothly. I'm not 100% sure if this is a DOS game or if it's a Windows game, but I'm sure some of you must know.
When I use VDMS I get "incorrect IRQ", even though the IRQ is the same as in VDMS. And the games sound configuration isn't detecting my sound card, but I do get a choppy sound if I choose Soundblaster > 220 > 5 (IRQ). Still, it's too choppy to be enjoyable.
I get "incorret IRQ" in VDMS no matter what I choose.
Can anyone help?
I like games
Reply 1 of 4, by Snover
I have run this game without problem in Windows XP's NTVDM. It is a DOS game, not a Windows game, first, so this is getting moved to the correct place.
Are you running the game by right-clicking and choosing "Run with VDMS" rather than double-clicking on it? That's important.
Yes, it’s my fault.
Reply 2 of 4, by CrimsonStar
I'm using right click and run with VDMS of course. But it won't work.
EDIT: nevermind, I didn't know I had to use VDMS for the sound setup too.
I like games
Reply 3 of 4, by krkdnose
I haven't been able to get this game working in XP using VDMSound. Are there any options in VDMSound that need to be checked (beyond the default ones and maybe MSCDEX)?
When I run the normal.bat file with VDMS, it goes through a registration process and when that's done it just sits there. If I try to run the Norm.exe with VDMS it just sits there. No error messages or anything but nothing happens. I've set the sound options correctly. Does it need a VESA driver or something?
I've tried it in DOSbox and it loads fine, but it's just not playable like CrimsonStar said
Reply 4 of 4, by krkdnose
Never mind, I got it working.
For some reason, when the Logo.exe file was in the installation directory the game wouldn't start. If I delete it, it works fine.
