First post, by Dakkiller
I just reinstalled MS-DOS 6.22 on my DOS Machine and I would like to know which things I'll have to change to free up more Conventional memory while still keeping my drivers
CONFIG.SYS Settings
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS
DEVICEHIGH=C:\CTCM\CTCM.EXE
DEVICEHIGH=C:\DOS\OAKCDROM.SY /D:MSCD001
DOS=HIGH
REM ** FILES=30
FILES=40
AUTOEXEC.BAT Settings
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
C:\DOS\SMARTDRV.EXE /X
LH C:\DOS\MSCDEX.EXE /D:MSCD001
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
15,360K Total XMS and 2,222K of XMS is used up while 110K of Conventional Memory is used which leaves only 529KB's
Reply 2 of 5, by Dakkiller
Never Mind, i figured it out on my own
Reply 3 of 5, by ElectricMonk
At least it's not like the Ultima 7 "Voodoo Memory" from Origin Systems. Back in the day, that required special bootdisks, just to free enough Conventional Memory to let Voodoo load, and manage all mem above 640K.
Reply 4 of 5, by Mau1wurf1977
On my retro PC I don't use any fancy memory tricks but drivers that are small from the get go. The OAK driver is massive. I use an Acer driver instead.
Some mouse drivers are also large, CTMOUSE is much smaller. Do you really need SETVER?
My YouTube channel
Reply 5 of 5, by Matth79
I'll throw in another shrinking tip for anyone with UK Keyboard...
http://www.hrunk.com/tools/
Only source I've found for UKKEYB.SYS - a very much smaller UK keyboard mapper the just does the few keys that change between US/UK - says it does not work in DOSBox though
