get no sound in MS-dos, but get it in win98SE
First post, by Kanade
hi.
i just gat my old toshiba tecra 8100 laptop back. so i installed win98SE on it. it lagged when i play Need for speed 3 so i ahve desiced to only go whit mostly ms-dos games for it. but i have a porlvme here. when i reset into ms-dos mode. i get no sound. but the game works fine.
i can use the ms-dos prompt but then it crashes back to windows, it happend in "System Shock" i can start it up and so but i can start the game. i can do it in dos mode. so i tryd there to make a gam save it and start that way but no it did not work...
do you have any ideas on how i can get this running?
i think all my computer specc are normal and original. sadly it only has half of its memory so i only gat 128 MB in ram. its and intel 3 738 MHz cpu so i think its good. maybe abit fast but good for the later ames anyway.
thx for you help.
u can add me on skype: qvika_gilla, i ahve mutch easier to talk.
ps. i ahve not installed any updates or anything are thinking of doing that later on. useing the ENG ver of win98SE
Reply 4 of 36, by Solarstorm
But you need DOS drivers for DOS games. And by the looks of it there are no DOS drivers.
My YouTube Channel
Reply 5 of 36, by Kanade
ok then. so i can't play those games that crashes when i start them inside of windows.... its kinda looks like i can play some games. i get DOOM running fine when sound and all useing the ms-dos prompt. but well i guess i can't run all the games that way...
Reply 6 of 36, by Sammy
In Win 98 Not just doubleclick the Game.exe
Start a CommandPrompt Change to Game Directory and Start the Game.exe from there.
Maybe you Get an Error Message why Programm crashes (to less ram, no Ems, etc for example)
Then you can Change the ram settings by right clicking on the Game.exe
Reply 7 of 36, by Davros
select restart in msdos mode
at the dos prompt type the everything on the following line
type autoexec.bat > info.txt
post contents of info.txt here
Reply 8 of 36, by Kanade
i get that this file do not exist. are in C:\Windows
i think i shoudl be there. but well that file do not exist for me.
Reply 9 of 36, by bristlehog
autoexec.bat is located in root directory. It's C:\autoexec.bat.
Hardware comparisons and game system requirements: https://technical.city
Reply 10 of 36, by Kanade
ok. did not know.
ok i tryd that. its only crateing a info.txt file. and that file are empty. i tryd do this one more time when i ahve the file. nothingnew happend. i tryd even do it in win98 but still the some. i get an info.txt files whit nothing in it at all.
what does this mean? sorry for beening so noobish but i ahve never playd around whit MS-DOS i just wonna learn cuz its a cool stuff^^
Reply 11 of 36, by Mau1wurf1977
I've got some tutorials on my YT channel if you're interested!
This one in particular:
https://www.youtube.com/watch?v=XsZFdFbSzdA&l … ETU-VWM7mUe52OB
It shows you each and every step. But it's quite long so you need to be a bit patient 🤣
My YouTube channel
Reply 12 of 36, by Kanade
ok will che ck it out.
Reply 13 of 36, by Kanade
i looked at the videos. and i see first of. u use win95. i have win98SE is one diff. the others are we have diff in parts and stuff. i don't really know where my drivers are hehe. never done something liek this before feel so bad. and many of the folder you are linking to do not exist for me. so think thing u ahve are not working whit my computer. and i can't go down to win95 there is no drivers for me there.
so are there any other way i can do this?
Reply 14 of 36, by leileilol
Win98 has a device manager in the same place Win95 has one (right clicking "My Computer" and then "Properties"), and folders start existing when there's actual hardware detected in them. You should be able to find your soundcard and check its assigned resources within
Reply 15 of 36, by Davros
sorry try this
at the dos prompt type the everything on the following lines (press the enter key at the end of every line)
cd\
ps: the above line you do have to type in the word type ( not autoexec.bat > info.txt but type autoexec.bat > info.txt )
Reply 16 of 36, by Davros
if info.txt is still empty try this (press enter at the end of every line)
cd\
cls
type autoexec.bat
and write down what you see on screen and post it here
Reply 17 of 36, by Kanade
still nothing,
i tryd both way it gat me nothing. when i try to open the info.txt file i gat "badcommand or file"
theni did the other one but i did get nothing there.
its like this autoexec.bat are a file thats are not used for anything. i get like this:
C:\type autoexec.bat (enter)
C:\
thats how i looks.
Reply 18 of 36, by Jorpho
There's an easier way to do this.
Go to the Start menu, select Run, type SYSEDIT, and press Enter. Is there a window named AUTOEXEC.BAT? Is there anything written in it?
Reply 19 of 36, by Davros
but does that display the autoexec.bat for dos or the autoexec.bat for dos mode in windows ?
