I am searching for the best Dos-Gaming-Machine for al long time.
Actually I use an K6-III+@FSB66 (133-400Mhz) and deactivate Cpucache (batch) if it runs to fast.
This machine can be used for Dos and for Win95 (3dfx), but not all Dostitles run optimal with this machine.
There are some e.g. Wing-Commander1 that run way to fast.
If I cut this one machine into two, the perhaps I would choose an early Pentium oder 486 with a "turbo-Button"
in order to get a big range of performance-compatibility. On the other hand I will go for a PIII>500 for the 3dfx-gaming.
I did not made the decission yet.
Doc
