First post, by comradesean
I dumped the disk with a KryoFlux and created a 360kb disk image (40 track-9 sector). It simply hangs when I try to boot DOSBox or MESS with it. (PCE too, but I'm not sure it supports PCjr out of the box).
I've also noticed the CRC does not match with a booter image I found online.
mine -E98CF2EF
online -524C1991
Reply 2 of 7, by comradesean
collector wrote:
Did you use the GUI or the commandline?
GUI, but I ran it with logging enabled. Here are the results and the commandline used is listed on ln. 1.
DTC.exe -l15 -fC:\Users\Sean\Desktop\KryoFlux\KryoFlux Dumps\King's Quest (PCjr)\track -i0 -fC:\Users\Sean\Desktop\KryoFlux\KryoFlux Dumps\King's Quest (PCjr).img -k2 -i4 -r5 -d0 -p -e83 -dd0
v2.2 Jun 05 2007 10:59:13
00000447: status=0
0000045b: status=0
0000046f: reset=0
00000483: info=1, name=KryoFlux DiskSystem, version=2.20s, date=Dec 30 2012, time=02:33:19
00000497: info=2, hwid=1, hwrv=1, sck=24027428.5714285, ick=3003428.5714285625, wb=32768, wa=64, wq=8, wt=65535, wm=26
000004ab: device=0
000008fc: density=0
00000910: min_track=0
00000924: max_track=83
KryoFlux DiskTool Console, v2.51_Win32, uiv.1, Oct 29 2014, 16:45:42
(c) 2009-2014 KryoFlux Products & Services Ltd.
Developed by The Software Preservation Society, www.softpres.org
Licensed for private, non-commercial use only.
00000938: motor=1
00000cb9: side=0
00000ccd: track=0
00000ce1: stream=1
00001111: stream=0
00.0 : frev: 39247, drift: 0.791 us, tfer: 224356 B/s, rpm: 359.723
00.0 : band: 4.016 us, 6.058 us, 8.082 us
00.0 : base: 2.019 us [99.135%], band: 4.016 us, 6.058 us, 8.082 us
00.0 : MFM: OK*, trk: 000, sec: 9, *H +7
000011d9: motor=1
000011ed: side=1
00001202: track=0
00001216: stream=1
00001666: stream=0
00.1 : frev: 39142, drift: 0.524 us, tfer: 224796 B/s, rpm: 359.710
00.1 : band: 4.023 us, 6.054 us, 8.065 us
00.1 : base: 2.018 us [99.205%], band: 4.023 us, 6.054 us, 8.065 us
00.1 : MFM: <mismatch>, *N
0000172e: motor=1
00001742: side=0
00001757: track=1
000017c3: stream=1
00001bba: stream=0
01.0 : frev: 41805, drift: 0.999 us, tfer: 239386 B/s, rpm: 359.699
01.0 : band: 1.936 us, 3.976 us, 5.994 us, 7.856 us, 8.902 us?
00001c1e: motor=1
00001c32: side=1
00001c47: track=1
00001c5b: stream=1
00002060: stream=0
01.1 : frev: 41563, drift: 0.366 us, tfer: 237362 B/s, rpm: 359.702
01.1 : band: 1.918 us, 4.026 us, 6.039 us, 8.017 us, 8.973 us?
000020ec: motor=1
00002100: side=0
00002115: track=2
0000215b: stream=1
000025b1: stream=0
02.0 : frev: 38936, drift: 0.050 us, tfer: 223481 B/s, rpm: 359.695
02.0 : band: 4.018 us, 6.056 us, 8.068 us
02.0 : base: 2.019 us [99.210%], band: 4.018 us, 6.056 us, 8.068 us
02.0 : MFM: <mismatch>, *N
00002665: motor=1
00002679: side=1
0000268e: track=2
000026a2: stream=1
Show last 1304 lines
00002b02: stream=0
02.1 : frev: 38795, drift: 0.474 us, tfer: 222829 B/s, rpm: 359.701
02.1 : band: 4.023 us, 6.053 us, 8.063 us
02.1 : base: 2.018 us [99.230%], band: 4.023 us, 6.053 us, 8.063 us
02.1 : MFM: <mismatch>, *N
00002ba6: motor=1
00002bba: side=0
00002bcf: track=3
00002c15: stream=1
00003057: stream=0
03.0 : frev: 42303, drift: 0.441 us, tfer: 242380 B/s, rpm: 359.700
03.0 : band: 1.877 us, 3.105 us, 4.216 us, 6.176 us, 8.483 us
000030cf: motor=1
000030e3: side=1
000030f8: track=3
0000310c: stream=1
000034fb: stream=0
03.1 : frev: 43523, drift: 0.616 us, tfer: 248689 B/s, rpm: 359.702
03.1 : band: 2.035 us, 4.049 us, 6.001 us, 7.980 us, 8.899 us?
0000355f: motor=1
00003573: side=0
00003588: track=4
000035ce: stream=1
000039a4: stream=0
04.0 : frev: 38980, drift: 0.291 us, tfer: 222829 B/s, rpm: 359.696
04.0 : band: 2.124 us?, 3.266 us?, 4.031 us, 6.055 us, 8.063 us
04.0 : base: 2.018 us [99.171%], band: 2.124 us?, 3.266 us?, 4.031 us
04.0 : MFM: <mismatch>, *N
00003a44: motor=1
00003a58: side=1
00003a6d: track=4
00003a81: stream=1
00003e4c: stream=0
04.1 : frev: 41800, drift: 0.308 us, tfer: 237649 B/s, rpm: 359.704
04.1 : band: 4.026 us, 6.045 us, 8.072 us
04.1 : base: 2.015 us [99.204%], band: 4.026 us, 6.045 us, 8.072 us
04.1 : MFM: <mismatch>, *N
00003ed8: motor=1
00003eec: side=0
00003f01: track=5
00003f47: stream=1
0000439b: stream=0
05.0 : frev: 43347, drift: 0.483 us, tfer: 248689 B/s, rpm: 359.701
05.0 : band: 2.002 us, 4.012 us, 5.701 us, 7.868 us, 9.052 us?
00004413: motor=1
00004427: side=1
0000443c: track=5
00004450: stream=1
00004843: stream=0
05.1 : frev: 44866, drift: 0.108 us, tfer: 256478 B/s, rpm: 359.707
05.1 : band: 1.746 us, 2.788 us, 4.031 us, 5.994 us, 7.974 us
000048a7: motor=1
000048bb: side=0
000048d0: track=6
00004916: stream=1
00004ce8: stream=0
06.0 : frev: 44725, drift: 0.441 us, tfer: 256192 B/s, rpm: 359.704
06.0 : band: 4.022 us, 6.053 us, 8.066 us
06.0 : base: 2.018 us [99.218%], band: 4.022 us, 6.053 us, 8.066 us
06.0 : MFM: <mismatch>, *N
00004d9c: motor=1
00004db0: side=1
00004dc5: track=6
00004dd9: stream=1
0000523c: stream=0
06.1 : frev: 39543, drift: 0.816 us, tfer: 227021 B/s, rpm: 359.704
06.1 : band: 3.480 us?, 4.027 us, 6.050 us, 8.059 us
06.1 : base: 2.017 us [99.246%], band: 4.027 us, 6.050 us, 8.059 us
06.1 : MFM: OK*, trk: 003, sec: 9, *H +7
000052dc: motor=1
000052f0: side=0
00005305: track=7
0000534b: stream=1
0000578c: stream=0
07.0 : frev: 45463, drift: 0.524 us, tfer: 261264 B/s, rpm: 359.703
07.0 : band: 2.057 us, 4.105 us, 5.868 us, 7.335 us, 8.275 us?
00005804: motor=1
00005818: side=1
0000582d: track=7
00005841: stream=1
00005c35: stream=0
07.1 : frev: 44280, drift: 1.032 us, tfer: 252802 B/s, rpm: 359.709
07.1 : band: 2.023 us, 4.046 us, 5.949 us, 6.974 us, 8.046 us
00005c99: motor=1
00005cad: side=0
00005cc2: track=8
00005d08: stream=1
000060db: stream=0
08.0 : frev: 37766, drift: 0.425 us, tfer: 214652 B/s, rpm: 359.705
08.0 : band: 4.023 us, 6.051 us, 8.067 us
08.0 : base: 2.017 us [99.219%], band: 4.023 us, 6.051 us, 8.067 us
08.0 : MFM: OK*, trk: 004, sec: 9, *H +9
0000617f: motor=1
00006193: side=1
000061a8: track=8
000061bc: stream=1
00006583: stream=0
08.1 : frev: 38124, drift: 0.799 us, tfer: 216354 B/s, rpm: 359.711
08.1 : band: 3.327 us?, 4.028 us, 6.049 us, 7.201 us?, 8.064 us
08.1 : base: 2.016 us [99.220%], band: 3.327 us?, 4.028 us, 6.049 us
08.1 : MFM: OK*, trk: 004, sec: 9, *H +7
00006637: motor=1
0000664b: side=0
00006660: track=9
000066a6: stream=1
00006ad5: stream=0
09.0 : frev: 43123, drift: 0.708 us, tfer: 246550 B/s, rpm: 359.705
09.0 : band: 1.972 us, 4.092 us, 5.856 us, 7.219 us, 8.694 us?
00006b39: motor=1
00006b4d: side=1
00006b62: track=9
00006b76: stream=1
00006f7c: stream=0
09.1 : frev: 43008, drift: 0.999 us, tfer: 245232 B/s, rpm: 359.709
09.1 : band: 2.058 us, 4.036 us, 5.966 us, 7.946 us, 8.942 us?
00006ff4: motor=1
00007008: side=0
0000701d: track=10
00007063: stream=1
00007422: stream=0
10.0 : frev: 38726, drift: 0.449 us, tfer: 220134 B/s, rpm: 359.707
10.0 : band: 2.001 us?, 2.781 us?, 4.026 us, 6.057 us, 8.057 us
10.0 : base: 2.019 us [99.227%], band: 2.001 us?, 2.781 us?, 4.026 us
10.0 : MFM: OK*, trk: 005, sec: 9, *H +9
000074b1: motor=1
000074c5: side=1
000074da: track=10
000074ee: stream=1
000078c8: stream=0
10.1 : frev: 38756, drift: 0.391 us, tfer: 221573 B/s, rpm: 359.711
10.1 : band: 4.018 us, 6.051 us, 8.075 us
10.1 : base: 2.017 us [99.201%], band: 4.018 us, 6.051 us, 8.075 us
10.1 : MFM: OK*, trk: 005, sec: 9, *H +9
00007968: motor=1
0000797c: side=0
00007991: track=11
000079d7: stream=1
00007e19: stream=0
11.0 : frev: 43697, drift: 0.499 us, tfer: 250592 B/s, rpm: 359.711
11.0 : band: 1.974 us, 4.210 us, 6.000 us, 7.510 us, 8.434 us
00007e7d: motor=1
00007e91: side=1
00007ea6: track=11
00007eba: stream=1
000082c4: stream=0
11.1 : frev: 44239, drift: 0.100 us, tfer: 251969 B/s, rpm: 359.710
11.1 : band: 1.959 us, 4.049 us, 6.054 us, 7.991 us, 9.200 us?
00008328: motor=1
0000833c: side=0
00008351: track=12
00008397: stream=1
00008768: stream=0
12.0 : frev: 38644, drift: 0.166 us, tfer: 220826 B/s, rpm: 359.713
12.0 : band: 4.024 us, 6.055 us, 8.079 us
12.0 : base: 2.018 us [99.120%], band: 4.024 us, 6.055 us, 8.079 us
12.0 : MFM: OK*, trk: 006, sec: 9, *H +7
000087f4: motor=1
00008808: side=1
0000881d: track=12
00008831: stream=1
00008c10: stream=0
12.1 : frev: 38704, drift: 0.749 us, tfer: 221324 B/s, rpm: 359.718
12.1 : band: 4.025 us, 6.053 us, 8.062 us
12.1 : base: 2.018 us [99.219%], band: 4.025 us, 6.053 us, 8.062 us
12.1 : MFM: OK*, trk: 006, sec: 9, *H +7
00008c9c: motor=1
00008cb0: side=0
00008cc5: track=13
00008d0b: stream=1
00009161: stream=0
13.0 : frev: 43571, drift: 1.981 us, tfer: 250318 B/s, rpm: 359.715
13.0 : band: 1.925 us, 4.021 us, 5.762 us, 7.063 us, 8.146 us?
000091c5: motor=1
000091d9: side=1
000091ee: track=13
00009202: stream=1
00009608: stream=0
13.1 : frev: 43458, drift: 0.108 us, tfer: 247615 B/s, rpm: 359.716
13.1 : band: 2.046 us, 4.063 us, 5.966 us, 6.920 us, 8.068 us
0000966c: motor=1
00009680: side=0
00009695: track=14
000096db: stream=1
00009aaf: stream=0
14.0 : frev: 38488, drift: 1.190 us, tfer: 220085 B/s, rpm: 359.713
14.0 : band: 4.013 us, 6.051 us, 8.058 us
14.0 : base: 2.017 us [99.322%], band: 4.013 us, 6.051 us, 8.058 us
14.0 : MFM: OK*, trk: 007, sec: 9, *H +7
00009b3b: motor=1
00009b4f: side=1
00009b64: track=14
00009b78: stream=1
00009f57: stream=0
14.1 : frev: 38983, drift: 0.133 us, tfer: 222829 B/s, rpm: 359.720
14.1 : band: 4.020 us, 6.052 us, 8.057 us
14.1 : base: 2.017 us [99.283%], band: 4.020 us, 6.052 us, 8.057 us
14.1 : MFM: OK*, trk: 007, sec: 9, *H +9
00009fcf: motor=1
00009fe3: side=0
00009ff8: track=15
0000a03e: stream=1
0000a400: stream=0
15.0 : frev: 43839, drift: 1.157 us, tfer: 250364 B/s, rpm: 359.716
15.0 : band: 1.760 us, 3.139 us, 4.534 us, 5.719 us, 6.880 us
0000a464: motor=1
0000a478: side=1
0000a48d: track=15
0000a4a1: stream=1
0000a8a6: stream=0
15.1 : frev: 44363, drift: 1.049 us, tfer: 252802 B/s, rpm: 359.718
15.1 : band: 1.971 us, 4.047 us, 5.963 us, 6.937 us, 8.041 us
0000a946: motor=1
0000a95a: side=0
0000a96f: track=16
0000a9b5: stream=1
0000adf4: stream=0
16.0 : frev: 38312, drift: 0.133 us, tfer: 219103 B/s, rpm: 359.719
16.0 : band: 4.023 us, 6.058 us, 8.073 us
16.0 : base: 2.019 us [99.143%], band: 4.023 us, 6.058 us, 8.073 us
16.0 : MFM: OK*, trk: 008, sec: 9, *H +9
0000ae80: motor=1
0000ae94: side=1
0000aea9: track=16
0000aebd: stream=1
0000b29d: stream=0
16.1 : frev: 38635, drift: 0.849 us, tfer: 220826 B/s, rpm: 359.723
16.1 : band: 2.224 us?, 4.023 us, 6.045 us, 7.422 us?, 8.071 us
16.1 : base: 2.015 us [99.232%], band: 4.023 us, 6.045 us, 7.422 us?
16.1 : MFM: OK*, trk: 008, sec: 9, *H +7
0000b33d: motor=1
0000b351: side=0
0000b366: track=17
0000b3ac: stream=1
0000b7ee: stream=0
17.0 : frev: 43578, drift: 0.932 us, tfer: 249773 B/s, rpm: 359.722
17.0 : band: 2.101 us, 4.196 us, 5.684 us, 7.065 us, 8.205 us?
0000b852: motor=1
0000b866: side=1
0000b87b: track=17
0000b88f: stream=1
0000bc98: stream=0
17.1 : frev: 43370, drift: 1.307 us, tfer: 247615 B/s, rpm: 359.725
17.1 : band: 1.823 us, 3.137 us, 4.154 us, 5.997 us, 7.674 us
0000bcfc: motor=1
0000bd10: side=0
0000bd25: track=18
0000bd6b: stream=1
0000c13e: stream=0
18.0 : frev: 38315, drift: 0.674 us, tfer: 219103 B/s, rpm: 359.722
18.0 : band: 3.325 us?, 4.018 us, 6.057 us, 8.055 us
18.0 : base: 2.019 us [99.274%], band: 3.325 us?, 4.018 us, 6.057 us
18.0 : MFM: OK*, trk: 009, sec: 9, *H +5
0000c1de: motor=1
0000c1f2: side=1
0000c207: track=18
0000c21b: stream=1
0000c5e7: stream=0
18.1 : frev: 38506, drift: 0.716 us, tfer: 218664 B/s, rpm: 359.729
18.1 : band: 1.891 us?, 3.220 us?, 4.024 us, 6.052 us, 8.064 us
18.1 : base: 2.017 us [99.226%], band: 1.891 us?, 3.220 us?, 4.024 us
18.1 : MFM: OK*, trk: 009, sec: 9, *H +9
0000c65f: motor=1
0000c673: side=0
0000c688: track=19
0000c6ce: stream=1
0000ca8a: stream=0
19.0 : frev: 44035, drift: 0.308 us, tfer: 251646 B/s, rpm: 359.724
19.0 : band: 2.010 us, 4.185 us, 5.686 us, 6.922 us, 7.985 us
0000caee: motor=1
0000cb02: side=1
0000cb17: track=19
0000cb2b: stream=1
0000cf32: stream=0
19.1 : frev: 44605, drift: 1.781 us, tfer: 254203 B/s, rpm: 359.725
19.1 : band: 1.797 us, 3.066 us, 4.110 us, 5.720 us, 6.862 us?
0000cf96: motor=1
0000cfaa: side=0
0000cfbf: track=20
0000d005: stream=1
0000d3d8: stream=0
20.0 : frev: 38658, drift: 0.350 us, tfer: 221075 B/s, rpm: 359.726
20.0 : band: 4.028 us, 6.060 us, 8.085 us
20.0 : base: 2.020 us [99.039%], band: 4.028 us, 6.060 us, 8.085 us
20.0 : MFM: OK*, trk: 010, sec: 9, *H +4
0000d464: motor=1
0000d478: side=1
0000d48d: track=20
0000d4a1: stream=1
0000d880: stream=0
20.1 : frev: 38840, drift: 0.108 us, tfer: 222074 B/s, rpm: 359.731
20.1 : band: 4.016 us, 6.048 us, 8.073 us
20.1 : base: 2.016 us [99.239%], band: 4.016 us, 6.048 us, 8.073 us
20.1 : MFM: OK*, trk: 010, sec: 9, *H +9
0000d90c: motor=1
0000d920: side=0
0000d935: track=21
0000d97b: stream=1
0000ddd5: stream=0
21.0 : frev: 43468, drift: 0.283 us, tfer: 249773 B/s, rpm: 359.729
21.0 : band: 1.963 us, 4.119 us, 6.254 us, 8.733 us, 9.558 us?
0000de4d: motor=1
0000de61: side=1
0000de76: track=21
0000de8a: stream=1
0000e278: stream=0
21.1 : frev: 42702, drift: 0.549 us, tfer: 245057 B/s, rpm: 359.731
21.1 : band: 2.051 us, 3.985 us, 5.871 us, 7.863 us, 9.094 us?
0000e2dc: motor=1
0000e2f0: side=0
0000e305: track=22
0000e34b: stream=1
0000e721: stream=0
22.0 : frev: 38773, drift: 0.316 us, tfer: 221573 B/s, rpm: 359.728
22.0 : band: 1.879 us?, 3.660 us?, 4.022 us, 6.051 us, 8.055 us
22.0 : base: 2.017 us [99.287%], band: 1.879 us?, 3.660 us?, 4.022 us
22.0 : MFM: OK*, trk: 011, sec: 9, *H +7
0000e7ad: motor=1
0000e7c1: side=1
0000e7d6: track=22
0000e7ea: stream=1
0000ebcd: stream=0
22.1 : frev: 38493, drift: 0.100 us, tfer: 220085 B/s, rpm: 359.733
22.1 : band: 4.022 us, 6.046 us, 8.070 us
22.1 : base: 2.015 us [99.236%], band: 4.022 us, 6.046 us, 8.070 us
22.1 : MFM: OK*, trk: 011, sec: 9, *H +7
0000ec9a: motor=1
0000ecae: side=0
0000ecc3: track=23
0000ed09: stream=1
0000f118: stream=0
23.0 : frev: 44564, drift: 0.042 us, tfer: 254768 B/s, rpm: 359.734
23.0 : band: 1.996 us, 4.183 us, 5.774 us, 6.920 us, 8.185 us
0000f190: motor=1
0000f1a4: side=1
0000f1b9: track=23
0000f1cd: stream=1
0000f5c2: stream=0
23.1 : frev: 43038, drift: 0.524 us, tfer: 247081 B/s, rpm: 359.732
23.1 : band: 1.958 us, 4.043 us, 5.950 us, 7.900 us, 9.033 us?
0000f626: motor=1
0000f63a: side=0
0000f64f: track=24
0000f695: stream=1
0000fa66: stream=0
24.0 : frev: 38542, drift: 0.316 us, tfer: 220331 B/s, rpm: 359.730
24.0 : band: 3.327 us?, 4.024 us, 6.049 us, 8.070 us
24.0 : base: 2.016 us [99.205%], band: 3.327 us?, 4.024 us, 6.049 us
24.0 : MFM: OK*, trk: 012, sec: 9, *H +7
0000faf5: motor=1
0000fb09: side=1
0000fb1e: track=24
0000fb32: stream=1
0000ff0f: stream=0
24.1 : frev: 38399, drift: 0.583 us, tfer: 219593 B/s, rpm: 359.736
24.1 : band: 4.019 us, 6.048 us, 8.063 us
24.1 : base: 2.016 us [99.282%], band: 4.019 us, 6.048 us, 8.063 us
24.1 : MFM: OK*, trk: 012, sec: 9, *H +9
0000ff87: motor=1
0000ff9b: side=0
0000ffb0: track=25
0000fff6: stream=1
000103b3: stream=0
25.0 : frev: 43276, drift: 0.666 us, tfer: 247215 B/s, rpm: 359.735
25.0 : band: 1.688 us, 2.822 us, 4.160 us, 5.905 us, 7.234 us
00010417: motor=1
0001042b: side=1
00010440: track=25
00010454: stream=1
0001085c: stream=0
25.1 : frev: 39501, drift: 0.100 us, tfer: 225644 B/s, rpm: 359.735
25.1 : band: 1.683 us, 2.895 us, 4.019 us, 5.851 us, 7.895 us
00010924: motor=1
00010938: side=0
0001094d: track=26
00010993: stream=1
00010dad: stream=0
26.0 : frev: 38664, drift: 0.108 us, tfer: 221324 B/s, rpm: 359.732
26.0 : band: 4.020 us, 6.056 us, 8.041 us
26.0 : base: 2.019 us [99.349%], band: 4.020 us, 6.056 us, 8.041 us
26.0 : MFM: OK*, trk: 013, sec: 9, *H +9
00010e89: motor=1
00010e9d: side=1
00010eb2: track=26
00010ec6: stream=1
000112fd: stream=0
26.1 : frev: 38736, drift: 0.300 us, tfer: 221324 B/s, rpm: 359.734
26.1 : band: 4.022 us, 6.050 us, 8.068 us
26.1 : base: 2.017 us [99.221%], band: 4.022 us, 6.050 us, 8.068 us
26.1 : MFM: OK*, trk: 013, sec: 9, *H +9
00011375: motor=1
00011389: side=0
0001139e: track=27
000113e4: stream=1
000117a5: stream=0
27.0 : frev: 44344, drift: 0.067 us, tfer: 253594 B/s, rpm: 359.735
27.0 : band: 1.776 us, 3.080 us, 4.345 us, 5.744 us, 6.800 us
00011809: motor=1
0001181d: side=1
00011832: track=27
00011846: stream=1
00011c4b: stream=0
27.1 : frev: 41865, drift: 0.117 us, tfer: 239678 B/s, rpm: 359.738
27.1 : band: 1.837 us, 2.944 us, 4.035 us, 5.857 us, 7.944 us
00011caf: motor=1
00011cc3: side=0
00011cd8: track=28
00011d1e: stream=1
000120f2: stream=0
28.0 : frev: 38535, drift: 0.333 us, tfer: 220331 B/s, rpm: 359.738
28.0 : band: 2.414 us?, 4.025 us, 6.050 us, 8.069 us
28.0 : base: 2.017 us [99.201%], band: 4.025 us, 6.050 us, 8.069 us
28.0 : MFM: OK*, trk: 014, sec: 9, *H +7
00012192: motor=1
000121a6: side=1
000121bb: track=28
000121cf: stream=1
0001259b: stream=0
28.1 : frev: 38973, drift: 0.050 us, tfer: 222829 B/s, rpm: 359.738
28.1 : band: 3.264 us?, 4.021 us, 6.053 us, 8.066 us
28.1 : base: 2.018 us [99.222%], band: 3.264 us?, 4.021 us, 6.053 us
28.1 : MFM: OK*, trk: 014, sec: 9, *H +5
00012663: motor=1
00012677: side=0
0001268c: track=29
000126d2: stream=1
00012aed: stream=0
29.0 : frev: 43381, drift: 2.098 us, tfer: 247348 B/s, rpm: 359.740
29.0 : band: 1.917 us, 4.035 us, 5.918 us, 7.768 us, 9.492 us?
00012b51: motor=1
00012b65: side=1
00012b7a: track=29
00012b8e: stream=1
00012f91: stream=0
29.1 : frev: 39391, drift: 0.166 us, tfer: 225127 B/s, rpm: 359.740
29.1 : band: 1.806 us, 2.874 us?, 4.056 us, 5.988 us, 7.991 us
00012fe3: motor=1
00012ff7: side=0
0001300c: track=30
00013052: stream=1
00013439: stream=0
30.0 : frev: 38579, drift: 0.474 us, tfer: 220579 B/s, rpm: 359.735
30.0 : band: 4.022 us, 6.049 us, 8.052 us
30.0 : base: 2.016 us [99.321%], band: 4.022 us, 6.049 us, 8.052 us
30.0 : MFM: OK*, trk: 015, sec: 9, *H +5
000134b1: motor=1
000134c5: side=1
000134da: track=30
000134ee: stream=1
000138de: stream=0
30.1 : frev: 38417, drift: 0.649 us, tfer: 219838 B/s, rpm: 359.741
30.1 : band: 4.022 us, 6.050 us, 8.080 us
30.1 : base: 2.017 us [99.158%], band: 4.022 us, 6.050 us, 8.080 us
30.1 : MFM: OK*, trk: 015, sec: 9, *H +9
0001396a: motor=1
0001397e: side=0
00013993: track=31
000139d9: stream=1
00013e30: stream=0
31.0 : frev: 45196, drift: 0.857 us, tfer: 259196 B/s, rpm: 359.739
31.0 : band: 1.976 us, 4.128 us, 6.084 us, 7.803 us?, 8.702 us?
00013ea8: motor=1
00013ebc: side=1
00013ed1: track=31
00013ee5: stream=1
000142da: stream=0
31.1 : frev: 41918, drift: 0.508 us, tfer: 240558 B/s, rpm: 359.745
31.1 : band: 1.951 us, 4.049 us, 5.945 us, 7.483 us, 8.841 us?
0001433e: motor=1
00014352: side=0
00014367: track=32
000143ad: stream=1
0001477f: stream=0
32.0 : frev: 38480, drift: 0.075 us, tfer: 220085 B/s, rpm: 359.742
32.0 : band: 1.722 us?, 3.252 us?, 4.029 us, 6.054 us, 8.072 us
32.0 : base: 2.018 us [99.137%], band: 3.252 us?, 4.029 us, 6.054 us
32.0 : MFM: OK*, trk: 016, sec: 9, *H +9
000147fa: motor=1
0001480e: side=1
00014823: track=32
00014837: stream=1
00014c25: stream=0
32.1 : frev: 38670, drift: 0.741 us, tfer: 221075 B/s, rpm: 359.743
32.1 : band: 4.024 us, 6.051 us, 8.064 us
32.1 : base: 2.017 us [99.233%], band: 4.024 us, 6.051 us, 8.064 us
32.1 : MFM: OK*, trk: 016, sec: 9, *H +4
00014cc5: motor=1
00014cd9: side=0
00014cee: track=33
00014d34: stream=1
00015178: stream=0
33.0 : frev: 44574, drift: 0.549 us, tfer: 255336 B/s, rpm: 359.743
33.0 : band: 1.793 us, 3.115 us, 4.224 us, 5.859 us, 7.317 us
000151dc: motor=1
000151f0: side=1
00015205: track=33
00015219: stream=1
0001561f: stream=0
33.1 : frev: 39952, drift: 0.325 us, tfer: 228264 B/s, rpm: 359.747
33.1 : band: 1.736 us, 2.795 us, 4.053 us, 5.979 us, 7.902 us
00015683: motor=1
00015697: side=0
000156ac: track=34
000156f2: stream=1
00015ac5: stream=0
34.0 : frev: 39168, drift: 0.483 us, tfer: 223845 B/s, rpm: 359.744
34.0 : band: 3.241 us?, 4.017 us, 6.042 us, 8.068 us
34.0 : base: 2.014 us [99.296%], band: 3.241 us?, 4.017 us, 6.042 us
34.0 : MFM: OK*, trk: 017, sec: 9, *H +5
00015b51: motor=1
00015b65: side=1
00015b7a: track=34
00015b8e: stream=1
00015f6c: stream=0
34.1 : frev: 38642, drift: 0.358 us, tfer: 221075 B/s, rpm: 359.745
34.1 : band: 1.692 us?, 3.262 us?, 4.030 us, 6.055 us, 8.060 us
34.1 : base: 2.018 us [99.191%], band: 3.262 us?, 4.030 us, 6.055 us
34.1 : MFM: OK*, trk: 017, sec: 9, *H +4
00015ffb: motor=1
0001600f: side=0
00016024: track=35
0001606a: stream=1
000164bd: stream=0
35.0 : frev: 45219, drift: 0.150 us, tfer: 259710 B/s, rpm: 359.744
35.0 : band: 1.720 us, 3.096 us, 4.483 us, 5.769 us, 7.035 us
00016523: motor=1
00016537: side=1
0001654c: track=35
00016560: stream=1
00016966: stream=0
35.1 : frev: 42648, drift: 0.316 us, tfer: 244447 B/s, rpm: 359.749
35.1 : band: 1.967 us, 4.046 us, 5.984 us, 7.770 us, 9.033 us?
000169f2: motor=1
00016a06: side=0
00016a1b: track=36
00016a61: stream=1
00016eb7: stream=0
36.0 : frev: 38033, drift: 0.316 us, tfer: 217407 B/s, rpm: 359.748
36.0 : band: 4.022 us, 6.051 us, 8.070 us
36.0 : base: 2.017 us [99.206%], band: 4.022 us, 6.051 us, 8.070 us
36.0 : MFM: OK*, trk: 018, sec: 9, *H +7
00016f43: motor=1
00016f57: side=1
00016f6c: track=36
00016f80: stream=1
0001735e: stream=0
36.1 : frev: 38295, drift: 0.591 us, tfer: 218859 B/s, rpm: 359.748
36.1 : band: 4.021 us, 6.046 us, 8.059 us
36.1 : base: 2.015 us [99.304%], band: 4.021 us, 6.046 us, 8.059 us
36.1 : MFM: OK*, trk: 018, sec: 9, *H +5
000173d6: motor=1
000173ea: side=0
000173ff: track=37
00017445: stream=1
00017804: stream=0
37.0 : frev: 45016, drift: 0.841 us, tfer: 257583 B/s, rpm: 359.746
37.0 : band: 2.086 us, 4.158 us, 5.704 us, 7.037 us, 8.146 us?
00017868: motor=1
0001787c: side=1
00017891: track=37
000178a5: stream=1
00017cac: stream=0
37.1 : frev: 41356, drift: 0.474 us, tfer: 236790 B/s, rpm: 359.750
37.1 : band: 2.036 us, 4.063 us, 5.975 us, 7.942 us, 9.339 us?
00017d10: motor=1
00017d24: side=0
00017d39: track=38
00017d7f: stream=1
00018157: stream=0
38.0 : frev: 38577, drift: 0.816 us, tfer: 220579 B/s, rpm: 359.745
38.0 : band: 4.020 us, 6.052 us, 8.064 us
38.0 : base: 2.017 us [99.244%], band: 4.020 us, 6.052 us, 8.064 us
38.0 : MFM: OK*, trk: 019, sec: 9, *H +6
000181cf: motor=1
000181e3: side=1
000181f8: track=38
0001820c: stream=1
000185f4: stream=0
38.1 : frev: 38599, drift: 0.125 us, tfer: 220579 B/s, rpm: 359.752
38.1 : band: 4.027 us, 6.050 us, 8.079 us
38.1 : base: 2.017 us [99.132%], band: 4.027 us, 6.050 us, 8.079 us
38.1 : MFM: OK*, trk: 019, sec: 9, *H +7
0001866c: motor=1
00018680: side=0
00018695: track=39
000186db: stream=1
00018aa3: stream=0
39.0 : frev: 46145, drift: 0.666 us, tfer: 263857 B/s, rpm: 359.747
39.0 : band: 1.829 us, 3.271 us, 4.523 us, 5.655 us, 6.890 us
00018b57: motor=1
00018b6b: side=1
00018b80: track=39
00018b94: stream=1
00018ff7: stream=0
39.1 : frev: 43917, drift: 0.974 us, tfer: 251969 B/s, rpm: 359.750
39.1 : band: 1.971 us, 4.045 us, 5.967 us, 7.459 us, 8.841 us?
0001906f: motor=1
00019083: side=0
00019098: track=40
000190de: stream=1
00019498: stream=0
40.0 : frev: 38584, drift: 0.350 us, tfer: 219250 B/s, rpm: 359.751
40.0 : band: 3.318 us?, 4.024 us, 6.053 us, 8.064 us
40.0 : base: 2.018 us [99.217%], band: 3.318 us?, 4.024 us, 6.053 us
40.0 : MFM: OK*, trk: 020, sec: 9, *H +7
00019524: motor=1
00019538: side=1
0001954d: track=40
00019561: stream=1
00019944: stream=0
40.1 : frev: 38342, drift: 0.067 us, tfer: 219348 B/s, rpm: 359.750
40.1 : band: 4.024 us, 6.050 us, 8.070 us
40.1 : base: 2.017 us [99.197%], band: 4.024 us, 6.050 us, 8.070 us
40.1 : MFM: OK*, trk: 020, sec: 9, *H +7
000199bc: motor=1
000199d0: side=0
000199e5: track=41
00019a2b: stream=1
00019de8: stream=0
41.0 : frev: 45755, drift: 0.316 us, tfer: 261748 B/s, rpm: 359.746
41.0 : band: 1.807 us, 3.245 us, 4.502 us, 5.755 us, 7.137 us
00019e4c: motor=1
00019e60: side=1
00019e75: track=41
00019e89: stream=1
0001a28f: stream=0
41.1 : frev: 42458, drift: 0.574 us, tfer: 243668 B/s, rpm: 359.749
41.1 : band: 2.035 us, 4.054 us, 5.987 us, 7.855 us, 8.991 us?
0001a447: motor=1
0001a45b: side=0
0001a470: track=42
0001a4b6: stream=1
0001a88a: stream=0
42.0 : frev: 38453, drift: 0.083 us, tfer: 219838 B/s, rpm: 359.752
42.0 : band: 2.518 us?, 3.263 us?, 4.023 us, 6.052 us, 8.059 us
42.0 : base: 2.017 us [99.261%], band: 3.263 us?, 4.023 us, 6.052 us
42.0 : MFM: OK*, trk: 021, sec: 9, *H +9
0001a905: motor=1
0001a919: side=1
0001a92e: track=42
0001a942: stream=1
0001ad31: stream=0
42.1 : frev: 38704, drift: 0.508 us, tfer: 221324 B/s, rpm: 359.754
42.1 : band: 4.019 us, 6.058 us, 8.070 us
42.1 : base: 2.019 us [99.182%], band: 4.019 us, 6.058 us, 8.070 us
42.1 : MFM: OK*, trk: 021, sec: 9, *H +9
0001ada9: motor=1
0001adbd: side=0
0001add2: track=43
0001ae18: stream=1
0001b1db: stream=0
43.0 : frev: 46238, drift: 0.333 us, tfer: 264771 B/s, rpm: 359.750
43.0 : band: 1.727 us, 3.148 us, 4.479 us, 5.715 us, 6.950 us
0001b23f: motor=1
0001b253: side=1
0001b268: track=43
0001b27c: stream=1
0001b67c: stream=0
43.1 : frev: 44403, drift: 0.699 us, tfer: 253361 B/s, rpm: 359.751
43.1 : band: 1.814 us, 3.072 us, 4.179 us, 5.985 us, 7.778 us
0001b6e0: motor=1
0001b6f4: side=0
0001b709: track=44
0001b74f: stream=1
0001bb26: stream=0
44.0 : frev: 38325, drift: 0.108 us, tfer: 219103 B/s, rpm: 359.749
44.0 : band: 2.432 us?, 3.134 us?, 4.005 us, 6.054 us, 8.081 us
44.0 : base: 2.018 us [99.220%], band: 3.134 us?, 4.005 us, 6.054 us
44.0 : MFM: OK*, trk: 022, sec: 9, *H +7
0001bbc6: motor=1
0001bbda: side=1
0001bbef: track=44
0001bc03: stream=1
0001bfd2: stream=0
44.1 : frev: 38520, drift: 0.175 us, tfer: 220331 B/s, rpm: 359.754
44.1 : band: 3.348 us?, 4.006 us, 6.053 us, 7.501 us?, 8.065 us
44.1 : base: 2.018 us [99.308%], band: 4.006 us, 6.053 us, 7.501 us?
44.1 : MFM: OK*, trk: 022, sec: 9, *H +5
0001c05e: motor=1
0001c072: side=0
0001c087: track=45
0001c0cd: stream=1
0001c51e: stream=0
45.0 : frev: 47071, drift: 0.924 us, tfer: 268767 B/s, rpm: 359.756
45.0 : band: 1.749 us, 3.129 us, 4.281 us, 5.852 us, 7.212 us
0001c596: motor=1
0001c5aa: side=1
0001c5bf: track=45
0001c5d3: stream=1
0001c9c9: stream=0
45.1 : frev: 42055, drift: 0.058 us, tfer: 241444 B/s, rpm: 359.753
45.1 : band: 2.017 us, 4.045 us, 6.047 us, 8.032 us, 9.131 us?
0001ca2d: motor=1
0001ca41: side=0
0001ca56: track=46
0001ca9c: stream=1
0001ce6b: stream=0
46.0 : frev: 38754, drift: 0.050 us, tfer: 221573 B/s, rpm: 359.754
46.0 : band: 2.639 us?, 3.344 us?, 4.007 us, 6.061 us, 8.059 us
46.0 : base: 2.020 us [99.292%], band: 4.007 us, 6.061 us, 8.059 us
46.0 : MFM: OK*, trk: 023, sec: 9, *H +7
0001cefa: motor=1
0001cf0e: side=1
0001cf23: track=46
0001cf37: stream=1
0001d314: stream=0
46.1 : frev: 38398, drift: 0.491 us, tfer: 219593 B/s, rpm: 359.757
46.1 : band: 2.710 us?, 4.009 us, 6.057 us, 8.082 us
46.1 : base: 2.019 us [99.178%], band: 2.710 us?, 4.009 us, 6.057 us
46.1 : MFM: OK*, trk: 023, sec: 9, *H +9
0001d3a0: motor=1
0001d3b4: side=0
0001d3c9: track=47
0001d40f: stream=1
0001d865: stream=0
47.0 : frev: 48284, drift: 0.391 us, tfer: 277299 B/s, rpm: 359.756
47.0 : band: 1.760 us, 3.134 us, 4.457 us, 5.970 us, 7.750 us
0001d8e0: motor=1
0001d8f4: side=1
0001d909: track=47
0001d91d: stream=1
0001dd0c: stream=0
47.1 : frev: 43452, drift: 0.133 us, tfer: 250045 B/s, rpm: 359.754
47.1 : band: 2.005 us, 4.039 us, 6.037 us, 7.995 us, 9.155 us?
0001dd70: motor=1
0001dd84: side=0
0001dd99: track=48
0001dddf: stream=1
0001e1b8: stream=0
48.0 : frev: 38176, drift: 0.658 us, tfer: 218373 B/s, rpm: 359.755
48.0 : band: 4.008 us, 6.061 us, 8.075 us, 9.007 us?
48.0 : base: 2.020 us [99.205%], band: 4.008 us, 6.061 us, 8.075 us
48.0 : MFM: OK*, trk: 024, sec: 9, *H +7
0001e258: motor=1
0001e26c: side=1
0001e281: track=48
0001e295: stream=1
0001e659: stream=0
48.1 : frev: 38706, drift: 0.067 us, tfer: 220134 B/s, rpm: 359.757
48.1 : band: 3.196 us?, 4.002 us, 6.058 us, 7.501 us?, 8.073 us
48.1 : base: 2.019 us [99.257%], band: 3.196 us?, 4.002 us, 6.058 us
48.1 : MFM: OK*, trk: 024, sec: 9, *H +6
0001e6e5: motor=1
0001e6f9: side=0
0001e70e: track=49
0001e754: stream=1
0001eba9: stream=0
49.0 : frev: 47172, drift: 0.583 us, tfer: 269319 B/s, rpm: 359.756
49.0 : band: 1.910 us, 3.978 us, 5.941 us, 7.439 us, 8.639 us?
0001ec21: motor=1
0001ec35: side=1
0001ec4a: track=49
0001ec5e: stream=1
0001f052: stream=0
49.1 : frev: 40448, drift: 0.100 us, tfer: 231491 B/s, rpm: 359.756
49.1 : band: 2.033 us, 3.986 us, 5.103 us, 6.124 us, 8.031 us
0001f0b6: motor=1
0001f0ca: side=0
0001f0df: track=50
0001f125: stream=1
0001f4fb: stream=0
50.0 : frev: 41227, drift: 0.483 us, tfer: 235090 B/s, rpm: 359.754
50.0 : band: 2.408 us?, 3.346 us?, 4.010 us, 6.060 us, 8.068 us
50.0 : base: 2.020 us [99.234%], band: 4.010 us, 6.060 us, 8.068 us
50.0 : MFM: OK*, trk: 025, sec: 9, *H +7
0001f5af: motor=1
0001f5c3: side=1
0001f5d8: track=50
0001f5ec: stream=1
0001fa4c: stream=0
50.1 : frev: 39486, drift: 0.283 us, tfer: 226797 B/s, rpm: 359.758
50.1 : band: 4.006 us, 6.064 us, 7.498 us?, 8.045 us
50.1 : base: 2.021 us [99.368%], band: 4.006 us, 6.064 us, 7.498 us?
50.1 : MFM: OK*, trk: 025, sec: 9, *H +9
0001faf0: motor=1
0001fb04: side=0
0001fb19: track=51
0001fb5f: stream=1
0001ff99: stream=0
51.0 : frev: 49883, drift: 1.873 us, tfer: 285766 B/s, rpm: 359.757
51.0 : band: 1.755 us, 3.096 us, 4.496 us, 5.734 us, 6.666 us
00020014: motor=1
00020028: side=1
0002003d: track=51
00020051: stream=1
0002043f: stream=0
51.1 : frev: 44427, drift: 0.857 us, tfer: 254486 B/s, rpm: 359.756
51.1 : band: 1.681 us, 2.777 us, 4.068 us, 6.054 us, 7.840 us
000205e3: motor=1
000205f7: side=0
0002060c: track=52
00020652: stream=1
00020a3d: stream=0
52.0 : frev: 38706, drift: 0.516 us, tfer: 221324 B/s, rpm: 359.757
52.0 : band: 2.918 us?, 3.991 us, 6.052 us, 7.508 us?, 8.093 us
52.0 : base: 2.017 us [99.148%], band: 2.918 us?, 3.991 us, 6.052 us
52.0 : MFM: OK*, trk: 026, sec: 9, *H +7
00020ac9: motor=1
00020add: side=1
00020af2: track=52
00020b06: stream=1
00020ee2: stream=0
52.1 : frev: 38795, drift: 1.132 us, tfer: 221823 B/s, rpm: 359.756
52.1 : band: 2.673 us?, 3.194 us?, 3.985 us, 6.058 us, 8.055 us
52.1 : base: 2.019 us [99.288%], band: 2.673 us?, 3.194 us?, 3.985 us
52.1 : MFM: OK*, trk: 026, sec: 9, *H +7
00020f6e: motor=1
00020f82: side=0
00020f97: track=53
00020fdd: stream=1
00021434: stream=0
53.0 : frev: 48536, drift: 1.498 us, tfer: 279071 B/s, rpm: 359.756
53.0 : band: 1.759 us, 3.701 us, 5.733 us, 7.411 us, 8.204 us?
000214ac: motor=1
000214c0: side=1
000214d5: track=53
000214e9: stream=1
000218dc: stream=0
53.1 : frev: 42062, drift: 0.083 us, tfer: 241444 B/s, rpm: 359.760
53.1 : band: 2.018 us, 4.011 us, 6.032 us, 7.895 us, 9.000 us?
00021940: motor=1
00021954: side=0
00021969: track=54
000219af: stream=1
00021d81: stream=0
54.0 : frev: 38292, drift: 0.441 us, tfer: 218859 B/s, rpm: 359.758
54.0 : band: 3.000 us?, 3.996 us, 6.064 us, 8.079 us
54.0 : base: 2.021 us [99.189%], band: 3.000 us?, 3.996 us, 6.064 us
54.0 : MFM: OK*, trk: 027, sec: 9, *H +7
00021e36: motor=1
00021e4a: side=1
00021e5f: track=54
00021e73: stream=1
000222d4: stream=0
54.1 : frev: 39014, drift: 0.125 us, tfer: 224136 B/s, rpm: 359.760
54.1 : band: 3.991 us, 6.061 us, 8.072 us
54.1 : base: 2.020 us [99.207%], band: 3.991 us, 6.061 us, 8.072 us
54.1 : MFM: OK*, trk: 027, sec: 9, *H +9
00022363: motor=1
00022377: side=0
0002238c: track=55
000223d2: stream=1
00022826: stream=0
55.0 : frev: 50370, drift: 0.083 us, tfer: 289876 B/s, rpm: 359.756
55.0 : band: 1.684 us, 3.092 us, 4.485 us, 5.839 us, 7.137 us
000228a1: motor=1
000228b5: side=1
000228ca: track=55
000228de: stream=1
00022cce: stream=0
55.1 : frev: 46371, drift: 0.108 us, tfer: 265691 B/s, rpm: 359.760
55.1 : band: 1.906 us, 3.946 us, 5.881 us, 7.902 us, 9.604 us?
00022d32: motor=1
00022d46: side=0
00022d5b: track=56
00022da1: stream=1
00023175: stream=0
56.0 : frev: 37877, drift: 0.474 us, tfer: 215500 B/s, rpm: 359.761
56.0 : band: 4.004 us, 6.062 us, 8.084 us
56.0 : base: 2.021 us [99.166%], band: 4.004 us, 6.062 us, 8.084 us
56.0 : MFM: OK*, trk: 028, sec: 9, *H +7
00023201: motor=1
00023215: side=1
0002322a: track=56
0002323e: stream=1
00023619: stream=0
56.1 : frev: 38020, drift: 0.100 us, tfer: 217647 B/s, rpm: 359.761
56.1 : band: 3.269 us?, 3.994 us, 6.065 us, 7.504 us?, 8.064 us
56.1 : base: 2.022 us [99.245%], band: 3.269 us?, 3.994 us, 6.065 us
56.1 : MFM: OK*, trk: 028, sec: 9, *H +7
00023723: motor=1
00023737: side=0
0002374c: track=57
00023792: stream=1
00023b6a: stream=0
57.0 : frev: 50878, drift: 2.539 us, tfer: 291488 B/s, rpm: 359.758
57.0 : band: 1.755 us, 3.203 us, 4.462 us, 5.447 us, 6.438 us
00023bce: motor=1
00023be2: side=1
00023bf7: track=57
00023c0b: stream=1
00024013: stream=0
57.1 : frev: 47300, drift: 0.308 us, tfer: 272642 B/s, rpm: 359.759
57.1 : band: 1.920 us, 3.990 us, 6.067 us, 8.012 us, 9.196 us?
00024077: motor=1
0002408b: side=0
000240a0: track=58
000240e6: stream=1
000244bb: stream=0
58.0 : frev: 38581, drift: 0.100 us, tfer: 220579 B/s, rpm: 359.761
58.0 : band: 3.333 us?, 3.992 us, 6.059 us, 8.095 us
58.0 : base: 2.020 us [99.097%], band: 3.992 us, 6.059 us, 8.095 us
58.0 : MFM: OK*, trk: 029, sec: 9, *H +9
00024536: motor=1
0002454a: side=1
0002455f: track=58
00024573: stream=1
00024963: stream=0
58.1 : frev: 38208, drift: 0.466 us, tfer: 218373 B/s, rpm: 359.761
58.1 : band: 3.997 us, 6.063 us, 8.088 us
58.1 : base: 2.021 us [99.146%], band: 3.997 us, 6.063 us, 8.088 us
58.1 : MFM: OK*, trk: 029, sec: 9, *H +7
000249de: motor=1
000249f2: side=0
00024a07: track=59
00024a4d: stream=1
00024e05: stream=0
59.0 : frev: 50615, drift: 0.158 us, tfer: 290243 B/s, rpm: 359.759
59.0 : band: 1.758 us, 3.156 us, 4.349 us, 5.398 us, 6.301 us
00024e69: motor=1
00024e7d: side=1
00024e92: track=59
00024ea6: stream=1
000252af: stream=0
59.1 : frev: 49079, drift: 0.166 us, tfer: 281469 B/s, rpm: 359.760
59.1 : band: 1.895 us, 3.973 us, 6.055 us, 7.554 us?, 8.545 us?
00025313: motor=1
00025327: side=0
0002533c: track=60
00025382: stream=1
00025756: stream=0
60.0 : frev: 38476, drift: 0.732 us, tfer: 220085 B/s, rpm: 359.760
60.0 : band: 3.234 us?, 4.002 us, 6.064 us, 8.116 us
60.0 : base: 2.021 us [98.990%], band: 3.234 us?, 4.002 us, 6.064 us
60.0 : MFM: OK*, trk: 030, sec: 9, *H +7
000257f6: motor=1
0002580a: side=1
0002581f: track=60
00025833: stream=1
00025bf5: stream=0
60.1 : frev: 38134, drift: 0.283 us, tfer: 216640 B/s, rpm: 359.762
60.1 : band: 3.986 us, 4.476 us?, 6.061 us, 7.497 us?, 8.098 us
60.1 : base: 2.020 us [99.040%], band: 3.986 us, 6.061 us, 7.497 us?
60.1 : MFM: OK*, trk: 030, sec: 9, *H +5
00025c70: motor=1
00025c84: side=0
00025c99: track=61
00025cdf: stream=1
000260a4: stream=0
61.0 : frev: 50811, drift: 0.117 us, tfer: 290610 B/s, rpm: 359.762
61.0 : band: 1.792 us, 3.178 us, 4.444 us, 5.665 us, 6.688 us
0002611c: motor=1
00026130: side=1
00026145: track=61
00026159: stream=1
0002654c: stream=0
61.1 : frev: 47712, drift: 0.333 us, tfer: 275260 B/s, rpm: 359.759
61.1 : band: 1.925 us, 3.977 us, 6.021 us, 7.362 us?, 8.357 us?
000265b0: motor=1
000265c4: side=0
000265d9: track=62
0002661f: stream=1
000269f3: stream=0
62.0 : frev: 38773, drift: 0.092 us, tfer: 221823 B/s, rpm: 359.764
62.0 : band: 3.200 us?, 3.978 us, 6.065 us, 8.095 us, 8.497 us?
62.0 : base: 2.022 us [98.991%], band: 3.200 us?, 3.978 us, 6.065 us
62.0 : MFM: OK*, trk: 031, sec: 9, *H +7
00026a7f: motor=1
00026a93: side=1
00026aa8: track=62
00026abc: stream=1
00026e99: stream=0
62.1 : frev: 38818, drift: 0.266 us, tfer: 221823 B/s, rpm: 359.765
62.1 : band: 3.296 us?, 3.993 us, 5.483 us?, 6.067 us, 8.112 us
62.1 : base: 2.022 us [98.966%], band: 3.296 us?, 3.993 us, 5.483 us?
62.1 : MFM: OK*, trk: 031, sec: 9, *H +6
00026f11: motor=1
00026f25: side=0
00026f3a: track=63
00026f80: stream=1
0002733e: stream=0
63.0 : frev: 50485, drift: 0.541 us, tfer: 289510 B/s, rpm: 359.760
63.0 : band: 1.794 us, 3.230 us, 4.540 us, 5.796 us, 7.116 us
000273a2: motor=1
000273b6: side=1
000273cb: track=63
000273df: stream=1
000277e4: stream=0
63.1 : frev: 48837, drift: 0.708 us, tfer: 280265 B/s, rpm: 359.760
63.1 : band: 1.950 us, 4.028 us, 6.038 us, 7.308 us?, 8.410 us
00027848: motor=1
0002785c: side=0
00027871: track=64
000278b7: stream=1
00027c8c: stream=0
64.0 : frev: 38133, drift: 0.483 us, tfer: 217889 B/s, rpm: 359.764
64.0 : band: 3.238 us?, 3.999 us, 5.413 us?, 6.065 us, 8.086 us
64.0 : base: 2.022 us [99.157%], band: 3.238 us?, 3.999 us, 5.413 us?
64.0 : MFM: OK*, trk: 032, sec: 9, *H +7
00027d04: motor=1
00027d18: side=1
00027d2d: track=64
00027d41: stream=1
00028135: stream=0
64.1 : frev: 37834, drift: 0.383 us, tfer: 216687 B/s, rpm: 359.763
64.1 : band: 3.995 us, 6.069 us, 7.496 us?, 8.070 us
64.1 : base: 2.023 us [99.198%], band: 3.995 us, 6.069 us, 7.496 us?
64.1 : MFM: OK*, trk: 032, sec: 9, *H +9
000281d5: motor=1
000281e9: side=0
000281fe: track=65
00028244: stream=1
00028686: stream=0
65.0 : frev: 51222, drift: 0.832 us, tfer: 294804 B/s, rpm: 359.761
65.0 : band: 1.720 us, 3.142 us, 4.517 us, 5.647 us, 6.688 us
000286fe: motor=1
00028712: side=1
00028727: track=65
0002873b: stream=1
00028b2c: stream=0
65.1 : frev: 48278, drift: 0.757 us, tfer: 278944 B/s, rpm: 359.760
65.1 : band: 1.729 us, 2.854 us, 4.040 us, 5.835 us, 7.137 us
00028ba4: motor=1
00028bb8: side=0
00028bcd: track=66
00028c13: stream=1
00028fd4: stream=0
66.0 : frev: 38571, drift: 0.674 us, tfer: 219250 B/s, rpm: 359.762
66.0 : band: 1.728 us?, 3.056 us?, 3.999 us, 6.058 us, 8.101 us
66.0 : base: 2.019 us [99.109%], band: 3.056 us?, 3.999 us, 6.058 us
66.0 : MFM: OK*, trk: 033, sec: 9, *H +9
00029060: motor=1
00029074: side=1
00029089: track=66
0002909d: stream=1
00029479: stream=0
66.1 : frev: 38703, drift: 0.416 us, tfer: 221324 B/s, rpm: 359.765
66.1 : band: 3.205 us?, 3.996 us, 6.067 us, 7.487 us?, 8.098 us
66.1 : base: 2.022 us [99.062%], band: 3.205 us?, 3.996 us, 6.067 us
66.1 : MFM: OK*, trk: 033, sec: 9, *H +9
000296d1: motor=1
000296e5: side=0
000296fa: track=67
00029740: stream=1
00029b21: stream=0
67.0 : frev: 50945, drift: 0.508 us, tfer: 291812 B/s, rpm: 359.765
67.0 : band: 1.753 us, 3.180 us, 4.417 us, 5.636 us, 6.960 us
00029b99: motor=1
00029bad: side=1
00029bc2: track=67
00029bd6: stream=1
00029fc8: stream=0
67.1 : frev: 49141, drift: 0.383 us, tfer: 283295 B/s, rpm: 359.762
67.1 : band: 1.899 us, 3.872 us, 5.689 us, 7.087 us, 7.995 us?
0002a040: motor=1
0002a054: side=0
0002a069: track=68
0002a0af: stream=1
0002a46f: stream=0
68.0 : frev: 38178, drift: 0.275 us, tfer: 216354 B/s, rpm: 359.763
68.0 : band: 3.071 us?, 3.988 us, 6.058 us, 8.090 us
68.0 : base: 2.019 us [99.106%], band: 3.071 us?, 3.988 us, 6.058 us
68.0 : MFM: OK*, trk: 034, sec: 9, *H +7
0002a4fb: motor=1
0002a50f: side=1
0002a524: track=68
0002a538: stream=1
0002a912: stream=0
68.1 : frev: 38601, drift: 0.358 us, tfer: 220826 B/s, rpm: 359.762
68.1 : band: 3.189 us?, 3.986 us, 4.705 us?, 6.065 us, 8.023 us
68.1 : base: 2.022 us [99.434%], band: 3.189 us?, 3.986 us, 6.065 us
68.1 : MFM: OK*, trk: 034, sec: 9, *H +9
0002a9b2: motor=1
0002a9c6: side=0
0002a9db: track=69
0002aa21: stream=1
0002ae63: stream=0
69.0 : frev: 51973, drift: 0.508 us, tfer: 298989 B/s, rpm: 359.766
69.0 : band: 1.757 us, 3.194 us, 4.565 us, 5.771 us, 6.934 us
0002aedc: motor=1
0002aef0: side=1
0002af05: track=69
0002af19: stream=1
0002b30e: stream=0
69.1 : frev: 46761, drift: 0.100 us, tfer: 268491 B/s, rpm: 359.760
69.1 : band: 1.924 us, 3.936 us, 5.959 us, 8.085 us, 9.294 us?
0002b372: motor=1
0002b386: side=0
0002b39b: track=70
0002b3e1: stream=1
0002b7b6: stream=0
70.0 : frev: 38704, drift: 0.849 us, tfer: 221324 B/s, rpm: 359.763
70.0 : band: 3.198 us?, 3.961 us, 6.068 us, 8.047 us
70.0 : base: 2.023 us [99.142%], band: 3.198 us?, 3.961 us, 6.068 us
70.0 : MFM: OK*, trk: 035, sec: 9, *H +7
0002b82e: motor=1
0002b842: side=1
0002b857: track=70
0002b86b: stream=1
0002bc5b: stream=0
70.1 : frev: 39281, drift: 0.067 us, tfer: 224612 B/s, rpm: 359.762
70.1 : band: 1.910 us?, 3.167 us?, 4.015 us, 6.064 us, 8.065 us
70.1 : base: 2.021 us [99.201%], band: 1.910 us?, 3.167 us?, 4.015 us
70.1 : MFM: OK*, trk: 035, sec: 9, *H +9
0002bcd3: motor=1
0002bce7: side=0
0002bcfc: track=71
0002bd42: stream=1
0002c105: stream=0
71.0 : frev: 51860, drift: 0.774 us, tfer: 297106 B/s, rpm: 359.763
71.0 : band: 1.725 us, 2.941 us, 4.310 us, 5.490 us, 6.567 us
0002c169: motor=1
0002c17d: side=1
0002c192: track=71
0002c1a6: stream=1
0002c5ad: stream=0
71.1 : frev: 47108, drift: 1.199 us, tfer: 271351 B/s, rpm: 359.762
71.1 : band: 1.955 us, 3.979 us, 6.019 us, 8.013 us, 9.544 us?
0002c611: motor=1
0002c625: side=0
0002c63a: track=72
0002c680: stream=1
0002ca4f: stream=0
72.0 : frev: 37673, drift: 0.441 us, tfer: 214371 B/s, rpm: 359.761
72.0 : band: 3.279 us?, 4.093 us, 6.057 us, 7.946 us, 9.317 us?
72.0 : base: 2.019 us [98.869%], band: 3.279 us?, 4.093 us, 6.057 us
72.0 : MFM: OK*, trk: 036, sec: 9, *H +5
0002cac7: motor=1
0002cadb: side=1
0002caf0: track=72
0002cb04: stream=1
0002cef5: stream=0
72.1 : frev: 37668, drift: 0.083 us, tfer: 215500 B/s, rpm: 359.763
72.1 : band: 3.881 us, 6.078 us, 8.036 us
72.1 : base: 2.026 us [98.706%], band: 3.881 us, 6.078 us, 8.036 us
72.1 : MFM: OK*, trk: 036, sec: 9, *H +5
0002cf95: motor=1
0002cfa9: side=0
0002cfbe: track=73
0002d004: stream=1
0002d444: stream=0
73.0 : frev: 51951, drift: 0.150 us, tfer: 298082 B/s, rpm: 359.764
73.0 : band: 1.718 us, 3.142 us, 4.492 us, 5.596 us, 6.503 us
0002d4bc: motor=1
0002d4d0: side=1
0002d4e5: track=73
0002d4f9: stream=1
0002d8e8: stream=0
73.1 : frev: 42749, drift: 0.133 us, tfer: 247081 B/s, rpm: 359.764
73.1 : band: 2.047 us, 3.988 us, 6.034 us, 7.929 us, 9.389 us?
0002d94c: motor=1
0002d960: side=0
0002d975: track=74
0002d9bb: stream=1
0002dd98: stream=0
74.0 : frev: 37690, drift: 0.275 us, tfer: 214371 B/s, rpm: 359.761
74.0 : band: 3.239 us?, 4.093 us, 4.752 us?, 6.069 us, 7.901 us?
74.0 : base: 2.023 us [65.048%], band: 3.239 us?, 4.093 us, 6.069 us
74.0 : MFM: OK*, trk: 037, sec: 9, *H +5
0002de10: motor=1
0002de24: side=1
0002de39: track=74
0002de4d: stream=1
0002e240: stream=0
74.1 : frev: 37641, drift: 0.133 us, tfer: 215263 B/s, rpm: 359.763
74.1 : band: 3.295 us?, 4.093 us, 6.068 us, 7.900 us?, 8.820 us?
74.1 : base: 2.023 us [98.553%], band: 3.295 us?, 4.093 us, 6.068 us
74.1 : MFM: OK*, trk: 037, sec: 9, *H +9
0002e2b8: motor=1
0002e2cc: side=0
0002e2e1: track=75
0002e327: stream=1
0002e6e3: stream=0
75.0 : frev: 52407, drift: 0.491 us, tfer: 300169 B/s, rpm: 359.765
75.0 : band: 1.723 us, 3.010 us, 4.335 us, 5.595 us, 6.912 us
0002e75b: motor=1
0002e76f: side=1
0002e784: track=75
0002e798: stream=1
0002eb8f: stream=0
75.1 : frev: 44643, drift: 0.258 us, tfer: 256192 B/s, rpm: 359.763
75.1 : band: 1.924 us, 3.894 us, 5.717 us, 6.909 us, 8.081 us?
0002ebf3: motor=1
0002ec07: side=0
0002ec1c: track=76
0002ec62: stream=1
0002f031: stream=0
76.0 : frev: 37662, drift: 0.108 us, tfer: 214371 B/s, rpm: 359.760
76.0 : band: 3.068 us?, 3.883 us, 6.064 us, 8.145 us
76.0 : base: 2.021 us [98.187%], band: 3.068 us?, 3.883 us, 6.064 us
76.0 : MFM: OK*, trk: 038, sec: 9, *H +7
0002f0a9: motor=1
0002f0bd: side=1
0002f0d2: track=76
0002f0e6: stream=1
0002f4db: stream=0
76.1 : frev: 37686, drift: 0.308 us, tfer: 215736 B/s, rpm: 359.763
76.1 : band: 3.216 us?, 3.867 us, 6.068 us, 7.856 us?
76.1 : base: 2.023 us [98.080%], band: 3.216 us?, 3.867 us, 6.068 us
76.1 : MFM: OK*, trk: 038, sec: 9, *H +9
0002f57b: motor=1
0002f58f: side=0
0002f5a4: track=77
0002f5ea: stream=1
0002fa2a: stream=0
77.0 : frev: 52073, drift: 0.474 us, tfer: 298384 B/s, rpm: 359.765
77.0 : band: 1.755 us, 3.202 us, 4.514 us, 5.808 us, 6.971 us
0002faca: motor=1
0002fade: side=1
0002faf3: track=77
0002fb07: stream=1
0002fed2: stream=0
77.1 : frev: 42178, drift: 0.100 us, tfer: 238804 B/s, rpm: 359.767
77.1 : band: 1.934 us, 3.929 us, 6.076 us, 7.686 us, 9.388 us?
0002ff36: motor=1
0002ff4a: side=0
0002ff5f: track=78
0002ffa5: stream=1
00030379: stream=0
78.0 : frev: 37698, drift: 0.499 us, tfer: 214652 B/s, rpm: 359.763
78.0 : band: 3.886 us, 6.061 us, 8.139 us
78.0 : base: 2.020 us [98.254%], band: 3.886 us, 6.061 us, 8.139 us
78.0 : MFM: OK*, trk: 039, sec: 9, *H +6
000303f1: motor=1
00030405: side=1
0003041a: track=78
0003042e: stream=1
00030823: stream=0
78.1 : frev: 37660, drift: 0.449 us, tfer: 215500 B/s, rpm: 359.765
78.1 : band: 3.879 us, 6.061 us, 8.028 us
78.1 : base: 2.020 us [98.831%], band: 3.879 us, 6.061 us, 8.028 us
78.1 : MFM: OK*, trk: 039, sec: 9, *H +9
0003089b: motor=1
000308af: side=0
000308c4: track=79
0003090a: stream=1
00030cc5: stream=0
79.0 : frev: 54131, drift: 1.773 us, tfer: 309749 B/s, rpm: 359.765
79.0 : band: 1.753 us, 2.999 us, 4.279 us, 5.372 us, 6.781 us
00030d3d: motor=1
00030d51: side=1
00030d66: track=79
00030d7a: stream=1
00031168: stream=0
79.1 : frev: 44840, drift: 0.583 us, tfer: 257342 B/s, rpm: 359.765
79.1 : band: 1.952 us, 3.931 us, 5.909 us, 7.012 us, 8.335 us
000311e0: motor=1
000311f4: side=0
00031209: track=80
0003124f: stream=1
00031614: stream=0
80.0 : frev: 49454, drift: 0.075 us, tfer: 289876 B/s, rpm: 359.764
80.0 : band: 1.711 us, 2.775 us, 3.854 us, 4.991 us, 5.889 us
80.0 : base: 1.963 us [64.098%], band: 2.775 us, 3.854 us, 5.889 us
80.0 : MFM: <unformatted>
000316b4: motor=1
000316c8: side=1
000316dd: track=80
000316f1: stream=1
00031abd: stream=0
80.1 : frev: 50416, drift: 1.631 us, tfer: 295099 B/s, rpm: 359.765
80.1 : band: 1.715 us, 3.097 us, 4.344 us, 5.473 us, 6.462 us?
80.1 : base: 1.368 us [56.506%], band: 3.097 us, 4.344 us, 5.473 us
80.1 : MFM: <unformatted>
00031b71: motor=1
00031b85: side=0
00031b9a: track=81
00031be0: stream=1
00032009: stream=0
81.0 : frev: 49660, drift: 1.398 us, tfer: 291812 B/s, rpm: 359.765
81.0 : band: 1.718 us, 2.782 us, 3.915 us, 5.124 us, 6.316 us
00032081: motor=1
00032095: side=1
000320aa: track=81
000320be: stream=1
000324b4: stream=0
81.1 : frev: 50266, drift: 0.866 us, tfer: 294767 B/s, rpm: 359.768
81.1 : band: 1.711 us, 3.170 us, 4.392 us, 5.315 us, 6.189 us
0003252c: motor=1
00032540: side=0
00032555: track=82
0003259b: stream=1
0003295c: stream=0
82.0 : frev: 49585, drift: 0.433 us, tfer: 290243 B/s, rpm: 359.763
82.0 : band: 1.712 us, 3.075 us, 4.352 us, 5.171 us, 6.214 us?
82.0 : base: 2.176 us [61.008%], band: 3.075 us, 4.352 us, 6.214 us?
82.0 : MFM: <unformatted>
000329e8: motor=1
000329fc: side=1
00032a11: track=82
00032a25: stream=1
00032e02: stream=0
82.1 : frev: 50263, drift: 1.382 us, tfer: 294435 B/s, rpm: 359.764
82.1 : band: 1.718 us, 3.129 us, 4.507 us, 5.440 us, 6.362 us?
82.1 : base: 1.813 us [52.355%], band: 3.129 us, 5.440 us, 6.362 us?
82.1 : MFM: <unformatted>
00032ea2: motor=1
00032eb6: side=0
00032ecb: track=83
00032f11: stream=1
00033358: stream=0
83.0 : frev: 49483, drift: 0.599 us, tfer: 291885 B/s, rpm: 359.762
83.0 : band: 1.715 us, 3.386 us, 4.841 us, 5.789 us, 6.788 us
000333d0: motor=1
000333e4: side=1
000333f9: track=83
0003340d: stream=1
000337f8: stream=0
83.1 : frev: 50284, drift: 0.449 us, tfer: 294435 B/s, rpm: 359.766
83.1 : band: 1.715 us, 3.165 us, 4.475 us, 5.540 us, 6.309 us?
Enjoy your shiny new disk image!
Please consider helping us to preserve media and continue development:
www.softpres.org/donate
00033870: motor=0
It's a notchless disk so I'm not worried about the modified track warnings and there also wasn't a single bad sector.
Reply 3 of 7, by NewRisingSun
Which booter do you mean, the IBM release (which only runs on a PCjr), or the "PCjr disk" of the Sierra On-Line release (which runs on Tandy 1000 and PCjr)? The IBM version's copy protection is that the program image is stored in 1024-byte sized sectors (normal is 512). The "PCjr disk" of the Sierra On-Line release has several sectors with identical numbers but different content, which is a poor man's way of implementing a weak disk protection. The Tandy Radio Shack version release the same protection. The "PC disk" (i.e. CGA) of the Sierra On-Line release on the other hand uses the Formaster Copylock protection that screws up on machines faster than XT.
None of these protections are supported by publicly available DOSBox versions, and cannot be accurately represented by a normal .IMA/.IMG disk image either even if the emulator could emulate them. The publicly-available version is therefore necessarily a "cracked" version and therefore has a different CRC32.
Reply 4 of 7, by collector
I am afraid that I do not have a solution for you, but I am interested as I have not been able to get a working image of my copy either. I don't know if the disk is bad, if there is an issue with my drive or if I just don't have the switches worked out for this disk. As to the CRC, don't forget that there were two releases under the IBM label. If yours is the 1984, the image that you found may have been from the 2nd release.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 5 of 7, by comradesean
NewRisingSun wrote:
Which booter do you mean, the IBM release (which only runs on a PCjr), or the "PCjr disk" of the Sierra On-Line release (which runs on Tandy 1000 and PCjr)? The IBM version's copy protection is that the program image is stored in 1024-byte sized sectors (normal is 512). The "PCjr disk" of the Sierra On-Line release has several sectors with identical numbers but different content, which is a poor man's way of implementing a weak disk protection. The Tandy Radio Shack version uses the same protection. The "PC disk" (i.e. CGA) of the Sierra On-Line release uses the Formaster Copylock protection that screws up on machines faster than XT.
None of these protections are supported by publicly available DOSBox versions, and cannot be accurately represented by a normal .IMA/.IMG disk image either.
It's the 1984 hard case IBM release which lists the PCjr as a requirement on the back.
I see what you're talking about in HxCFloppyEmulator. The six tracks with five sectors definitely add up to 1024 bytes per sector. If I figure out how to convert it to to psi, will PCE support a pcJR booter out of the box or am I out of luck in emulating the disk?
Reply 6 of 7, by NewRisingSun
PCE has no PCjr support, not even on Git. MESS' "ibmpcjr" driver may accept .TD0 format images with non-standard sector sizes, but don't count on it. You could also convert to Transcopy format and try that with my Transcopy-capable development build of DOSBox, available upon PM request.
Reply 7 of 7, by vicvan
KQ1 (PCJR) has copy protection on the following track.
0 1 0 0 1 1 1024 MFM
0 1 1 0 1 2 1024 MFM
0 1 2 0 1 3 1024 MFM
0 1 3 0 1 4 1024 MFM
0 1 4 0 1 5 1024 MFM
1 0 0 1 0 1 1024 MFM
1 0 1 1 0 2 1024 MFM
1 0 2 1 0 3 1024 MFM
1 0 3 1 0 4 1024 MFM
1 0 4 1 0 5 1024 MFM
1 1 0 1 1 1 1024 MFM
1 1 1 1 1 2 1024 MFM
1 1 2 1 1 3 1024 MFM
1 1 3 1 1 4 1024 MFM
1 1 4 1 1 5 1024 MFM
2 0 0 2 0 1 1024 MFM
2 0 1 2 0 2 1024 MFM
2 0 2 2 0 3 1024 MFM
2 0 3 2 0 4 1024 MFM
2 0 4 2 0 5 1024 MFM
2 1 0 2 1 1 1024 MFM
2 1 1 2 1 2 1024 MFM
2 1 2 2 1 3 1024 MFM
2 1 3 2 1 4 1024 MFM
2 1 4 2 1 5 1024 MFM
3 0 0 3 0 1 1024 MFM
3 0 1 3 0 2 1024 MFM
3 0 2 3 0 3 1024 MFM
3 0 3 3 0 4 1024 MFM
3 0 4 3 0 5 1024 MFM
Rest of Track has no copy protection.
(Sector 1-9)
PCE recognize Copy Protected Track (Int-13 FDC Handling) but no PCjr/Tandy/PS2 supports.
I know King's Quest 1 (For pcbooter) exists as 3 types.
1) PCjr
2) PC
3) Tandy 1000
