First post, by Mike
- Member
Ok, before I use my scanner... I would like to know if using a data transfer cable (The only parrael cable I have) will damage the ports. Does it?
If you need the model number it is a Canon IX-4015
Sorry if this is on the wrong board, I cannot find any other boards to use.
