batch file question.
First post, by franpa
is there a command that makes a batch file not wait for commands to finish? as i would like to make one that loads worms2 and the IP changer at the same time.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 1 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
did you try playing with the command
start ?
Water flows down the stream
Reply 2 of 14, by franpa
no... could you give me an example of it in use?
my website
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
"start file.exe" (xp/9x)
Reply 4 of 14, by franpa
now that i have received what i wanted i say thanks to qbix and wd.
my website
Reply 5 of 14, by franpa
when using this...
start E:\Worms2\Worms2_IP_Changer.exe
start E:\Worms2\Frontend.exe
exit
worms 2 failes to find my custom option schemes and weapon schemes aswell as custom teams.
if there is a way to fix this within the batch file please let me know... sorry for the double post.
edit: fixed it by placing the bat file in my worms 2 directory and removing the paths from the bat file.
my website
Reply 7 of 14, by eL_PuSHeR
I think you mean QUOTES rather than ASTERISKS.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 9 of 14, by franpa
it works with the long name just fine without the " it was just setting the "start in" path incorrectly i think.
my website
Reply 10 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
start /?
might give more options (there are quite a few actually) (maybe google will help as well
I use
start .
(when on a windows pc) every now and then
Reply 11 of 14, by franpa
exit
and have it placed in a diff. directory to my worms 2 directory results in worms 2 not looking in its own folders for custom settings and stuff...
start Worms2_IP_Changer.exe
start Frontend.exe
exit
and have it placed in the worms 2 directory results in it working as it should.
my website
Reply 12 of 14, by bugs_bugger
Try
E:
cd Worms2
before starting worms. Current directory has to the right one then.
Reply 13 of 14, by franpa
i got it working... no need for more replies here.
my website
Reply 14 of 14, by franpa
call E:\Worms2\Worms2_IP_Changer.exe
call E:\Worms2\Frontend.exe
exit
this seams to be better then the start command... i found this out elsewhere.
my website
