First post, by tomservo6
I am running W2K and most DOS games work pretty well (without sound). Running them with VDMSound seems to work good for sound. However, Realms of Arkania: Blade of Destiny seems to be having problems with the mouse. The mouse cursor just sticks in one place in the middle of the screen and flickers if I move the mouse. This happens if I use VDMSound or not (although running the batch file with VDMSound makes it not load at all). I downloaded mouseset but there are no instructions on how to use it and when I double click on the program a DOS box just pops open and closes so I assume I'm not using it correctly. Also, if I use mouseset, can I also use VDMSound at the same time? Mouseset might not be the solution but I'm just trying to get the mouse to work in Realms of Arkania: Blade of Destiny.
