Reply 160 of 219, by pan069
- Oldbie
kdr wrote on 2021-05-25, 00:33:(Surely nobody ever built a 286 with just 128KB of RAM?!)
That was probably the memory on the EGA card, not the system memory (I hope so).
One thing I have noticed about EGA vs VGA is that while the latter offers more colors, it also increases the risk the graphics will look like blurred or discolored photo's. This is why I think some mid to late 90's games look awful despite their fairly realistic graphics and at the same time think much older games with CGA/EGA look better.
Also, when I look up Rise of the Dragon Amiga using Google I get VGA-like screenshots. Did the Amiga support 256 colors?
My GitHub:
https://github.com/peterswinkels
Peter Swinkels wrote on 2021-05-25, 09:27:One thing I have noticed about EGA vs VGA is that while the latter offers more colors, it also increases the risk the graphics will look like blurred or discolored photo's. This is why I think some mid to late 90's games look awful despite their fairly realistic graphics and at the same time think much older games with CGA/EGA look better.
Amiga supported 32 colors in OCS, 4096 colors in HAM mode. HAM was almost never used in games though, so games were mosty 32 (30+2 in Rise of the Dragon's case) colors.
This is a system that released in 1985 and in 1991 it could still trade blows with SVGA cards that nearly equalled the cost of the whole system. It was a computer from the future.
I see now, those 64 color graphics look a bit less detailed than the 256 color ones. Interesting how the IBM pc took over while it had less capable hardware at first.
My GitHub:
Teenage Mutant Ninja Turtles Manhattan Missions has some very nice VGA artwork. Very moody and full of nice smooth gradients.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Stormlord had a pretty awesome "dark romantic fantasy" aesthetic, especially for a 1989 game. An Amiga-esque gamut and presentation - you can tell where it was probably developed - but also released for DOS and other systems. While elements of the style associated with the Bitmap Brothers can be seen, Stormlord (by Hewson Consultants) actually predates Gods and most BB games.
Overall, it was stylistically a rare novelty of the times - and quite an amazing-looking one! - when encountered on a DOS machine.
Descent2 and Indy 4 are the most played games on my 486.
I also like to play Monkey Island 1/2 and Indy 3, but i know there is no 486 requiered for this games.
best regards
Paddy
Descent 2 on a 486?..
I assume that's because EGA always allowed for a "pixel-perfect" experience.
The EGA monitors were usually always digital (TTL transmission).
So it was necessary to perform careful drawing. Otherwise, the screens would look really ugly.
VGA on the other hand, was designed with many colours in mind (hence the switch to analogue RGB).
IBM's PS/2 series monitors, as well as cheaper no-name monitors were very blurry.
Most of you maybe can't remember this anymore. I'm talking about ~1987-1991 era 14"/15" VGA monitors without OSDs, not these modern CRTs that are often shown on Vogons.
The high amount of colours in VGA was used to allow for anti-aliasing/smoothing.
Well, at least in the 320x200 low-res MCGA mode often used by games.
In combination with a small VGA CRT of these days,
these blurry VGA titles didn't look bad, at all, seriously.
Rather, well, "organic" and realistic. I wished I could provide a picture. 😢
On a hi-res CRT with 17" and up.. Not so much.
When these games were made, 20" monitors were an extreme luxury.
Such sizes were used by CAD/CAM people or in the medical fields only.
And LCDs/TFTs.. Let's forget it. Or let's use the EGA version of the game. Seriously.
You're (we're) better of using a VGA to Composite converter box and use that on an LCD TV.
A cheap, one of course. A good one doesn't have the desired effect.
The blurriness restores some of the needed anti-aliasing.
*"Normal" VGA graphics mode was 640x480 in 16c (12h). That's what applications, simulations and adventure games used.
Games and applications that used it often have aged well.
It's smooth, but also detailed. Unlike 320x200 (13h).
I call it (640x480, 12h) normal, because it's similar to timings of VGA text-mode (~720x400?) - VGAs default mode.
Edit : That's a bit off-topic maybe, but let's please have a look at this screen shot.
It's Neko Project II emu on a Mac, running a Japanese game.
That PC-98 game uses 640x400 with a few colors.
Similar to some EGA titles in 640x350 (EGA native mode).
Despite being a digital screen shot, the graphics have aged well.
They look clean even on a modern TFT monitor.
Edit: Writing fixed up.
Found some samples of early, authentic VGA monitors.
appiah4 wrote on 2021-06-02, 11:19:Descent 2 on a 486?..
Hi!
Sure ! Have a look here :
Voodoo 1 vs. Voodoo 2 on a 486
best regards
Paddy
Jo22 wrote on 2021-06-02, 15:20:I assume that's because EGA always allowed for a "pixel-perfect" experience. The EGA monitors were usually always digital (TTL t […]
So it was necessary to perform careful drawing. Otherwise, the screens would look really ugly.VGA on the other hand, was designed with many colours in mind (hence the switch to analogue RGB).
I don't think it has anything to do with digital RGBI vs analogue RGB signals. To my eye, EGA artwork looks just as good when it's double-scanned at 400 lines on a standard VGA display.
I think the main issue with early VGA artwork is the severe lack of contrast. Probably due to using scanned-in artwork. It's primarily a palette issue, because the VGA display hardware is perfectly capable of showing bright saturated colours with high contrast (just look at VGA text mode for proof).
kdr wrote on 2021-06-02, 23:04:I don't think it has anything to do with digital RGBI vs analogue RGB signals. To my eye, EGA artwork looks just as good when it's double-scanned at 400 lines on a standard VGA display.
No, no, no. You get me wrong, I'm afraid. 😅
I meant to say that EGA artwork as such was rather carefully drawn by the artist *originally*,
because pure EGA systems it was intended for were not "forgiving":
Every little mistake was visible, because TTL signals are practically lossless.
There's no way that a mistake could be masked through the signal loss or the screen mask itself.
Thus, EGA artwork doesn't automagially degrade if zoomed or double-scanned properly on VGA systems, of course.
Sure, depending on the equipment, it may look less sharp or, the other way round, a bit more blocky here and there (without the scan lines), but..
Also, VGA cards without using emulation mode
do display 640x350 EGA graphics in a 640x400 view port on a VGA monitor just fine.
Not as sharp as on an EGA screen, maybe, but the result is acceptable.
kdr wrote on 2021-06-02, 23:04:I think the main issue with early VGA artwork is the severe lack of contrast. Probably due to using scanned-in artwork. It's primarily a palette issue, because the VGA display hardware is perfectly capable of showing bright saturated colours with high contrast (just look at VGA text mode for proof).
Surely, good "line work" (for contrast) is much more present/needed in drawings with a low colour depth, I think.
As an artist/illustrator, that's what you need to take care for if you're working with monochrome, 4 colors or 16 colors.
Let's just just look at all these Gameboy titles in 160x144 @4 shades of gray. 😉
Or the EGA drawings from the 80s that are out there.:
https://www.flickr.com/photos/94839221@N05/al … 157652364100484
Edit: These are merely more-or-less logical conclusions of mine, of course. I could be wrong, also.
I'd be really cool if we were in touch with artists/designers/programmers/etc of EGA titles of the time..
I think that their point-of-view might truely enlight us thanks to their "behind the scene" insider know how.
One of my favourite DOS games with beautiful graphics for a 486, is Lost Eden.
WolverineDK wrote on 2021-06-13, 19:29:One of my favourite DOS games with beautiful graphics for a 486, is Lost Eden.
Is that the early CD-ROM interactive movie game with dinosaurs? I was always curious about it, never played though..
appiah4 wrote on 2021-06-14, 21:46:WolverineDK wrote on 2021-06-13, 19:29:One of my favourite DOS games with beautiful graphics for a 486, is Lost Eden.
It was indeed a point and click adventure with dinosaurs.
It looks like someone enjoyed using the 'gradient fill' tool in their bitmap paint program for all the flat shapes in that game!
https://www.target-earth.net
I think including that game among the "most beautiful" of DOS games might be a bit of a stretch haha
Jo22 wrote on 2021-06-02, 15:51:Found some samples of early, authentic VGA monitors.
I still have some "samples" 2xVGA Color and 1xVGA Mono in my basement.
I did not have used them since 2010... I always preferred those small TFT's like the L367.
Doc
