First post, by sad_muso
Hello,
I am trying to get the music working correctly on Monkey Island 2. I am running under XP, and when I tried VDMSound, it did help, but the music still has a slightly 'inconsistent' feel to it- it occasinally slows down or speeds up, making it sound like it's skipping. It's sometimes a bit crackly too. Any ideas on how to resolve this, as I simply can't play this game without the excellent music of Michael Land!
Thanks,
Sad_muso
Retro King
Reply 1 of 3, by oneirotekt
I had a similar problem and fixed it with Speedset. Search the forums for how to use Speedset from within the LaunchPad. I use this setting in my autoexec:
speedset 0.05
Though it might be different for more and less powerful machines.
Reply 2 of 3, by maYO
You're right. Playing this game without it's excellent music would be a shame.
I suggest you try the SCUMM VM. It's a re-engineered engine for playing various Lucasarts adventure games based on the SCUMM engine.
You can find it at SCUMMVM
Installation and usage is pretty straight forward.
Hope i could help...
DOSBoxGui - multi platform DOSBox frontend
check my weblog (german only)
Reply 3 of 3, by Nicht Sehr Gut
Originally posted by oneirotekt I had a similar problem and fixed it with Speedset. Search the forums for how to use Speedset from within the LaunchPad.
DosBox should also be a viable option as it allows you to throttle cycles manually.
