First post, by Phasma Felis
(I wasn't sure if this belonged in this forum or DOSBox Development; if I got it wrong, please let me know.)
I'm working on a CD-audio mod for DOS X-COM. I'm pretty sure there's a set of standard audio calls supported in hardware by all CD-ROMs, but I can't find a list of these anywhere. Any suggestions?
I'm particularly hoping there's a command to loop a specific track, but failing that, I suppose retrieving the track length, playing, waiting the appropriate time, and then playing again would suffice. This is all in assembler, of course, so brevity is a virtue. 😀
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
well there are 2 things. First there is the mscdex interface. Games tend to use that.
(int 2f 15XX (check intlist))
for more information and for device specific stuff (device ioctl stuff) check MSCDEX.DOC or so it is called.
This is not dosbox related at all btw
Moving to dos
Water flows down the stream
Reply 2 of 3, by gerwin
Here are some old pascal sources that are about accessing the CD-Rom drive in pure DOS. I have not wrote these and never really tested them either, except the drive open/close thing years ago. Maybe they can show you which commands to use, in addition to what QBix already posted...
    CDROM.zip
    16.85 KiB
    376 downloads
    Pascal CD-Rom code for DOS
