First post, by rawta379
okay i have heroes 2 and i only have 2nd disc. I have installed on older computer before with this disc. i mounted my cdrom drive and then i switched to the drive which is e. then i did dir to see files and there is setup.exe that i did and it said it cannot be run in dos mod.
here wat i have it look like
mount e e:\ -t cdrom
e:
dir
heroes2 <DIR>
_AUTORUN <DIR>
_SETUP <DIR>
AUTORUN INF
README TXT
SETUP EXE
3 File(s)
3 Dir(s)
then i diddid setup.exe and it didnt work
