First post, by L Michaels
I have a Turtle Beach Santa Cruz in a pentium III PC running Windows ME. There's a legacy sound support program that comes with it that's supposed to allow you to run old games and programs that worked with OPL2/3 chips or old Soundblaster cards. When I try to use it, I have some weird things happen. For example, for every note it plays, instead of playing a single note, it plays intermittently so that you hear the note continue to turn on and off, instead of one smooth sound coming out. I just tried playing a music program under DOSBox and got the exact same effect when I tried to play notes using it instead of the legacy support program. If the information helps any, my card's set at IRQ 5. Sounds works great if you use Windows drivers, but any DOS applications or programs that try to directly work with OPL3 chips, get that weird effect when the legacy support program is running and don't work at all without the support. If anyone has any clues on how to get better support for sound for DOS applications using the Santa Cruz card, I'd appreciated hearing about them.
Thanks.
