First post, by Great Hierophant
- l33t
Out of this World (known in Europe as Another World) was ported from the Amiga to the PC, and the port to DOS was a little less than ideal. Graphically, things are excellent, but sound and control wise, they may not be.
Sound options for sound are Sound Blaster, Adlib, Pro Audio Spectrum (U.S. version only) or PC Speaker at 10kHz or 5kHz. The U.S. version also has a CM-32L/LAPC-I option, but it is not completely faithful to the Amiga music and sound effects. Keyboard or Joystick is supported for control.
The reference card recommends the Adlib for sound. Bizarrely, the Sound Blaster card "demands the most amount of processor time." Adlib is faster according to the reference card but has less sound quality. Joystick is not enabled by default and the user is warned that it takes up alot of processor time. There is a calibration option for the joystick. The manual also warns against using an Expanded Memory Manager for the same reason.
Here is my problem, on my 486DX2/66, I cannot get the joystick to respond properly with the Sound Blaster option at 10kHz. It will only respond properly with the 5kHz sound selection. I am using a Sound Blaster Pro for sound and joystick capabilities, and it does not offer any speed compensation. I have tried just about every slowdown option, yet nothing seems to work. The joystick will at best start to drift to the left or up, and at worst will not register right or down, depending on the speed setting.
A Gravis Gamepad is the ideal controller for this platformer-style game. However, these issues manifest themselves with a true analog joystick, and the game's calibration utility does not help. Would a speed adjustable gameport do any better? Do these settings work on a lesser CPU?
