First post, by Izanagi
I'm trying to get Betrayal at Krondor to run on Windows XP, and am having problems.
When I try to run Krondor through Windows, the screen goes to black for a few seconds, then knocks me back out to the desktop with no error message or anything.
When I try to run the program through the Command Prompt, the screen goes to black for a few seconds, then it boots me back to the Command Prompt with the error message, "You do not have enough memory to run Betrayal at Krondor. Try using the Make Boot Disk option from INSTALL."
But when I try to make a boot disk, the install comes up with an error message saying, "This game requires 1482K of extended memory and your machine does not have enough. Press any key to continue..." and then, "Boot disk was not created."
I've tried using the instructions at http://www.dosgames.com/xphints.php#2 , but, after doing that, the screen goes to black for a few seconds longer, and then dings an error and goes back to desktop with the message:
16 bit MS-DOS Subsystem
KRONDOR.EXE
The NTVDM CPU has encountered an illegal instruction.
CS:0000 IP:0077 OP:f0 37 05 12 02 Choose 'Close' to terminate the application.
And if I click 'Ignore' and re-maximize the program, it dings an error again, and kicks me back to Windows with the exact same error message. And if I ignore it a second time, and re-maximize the program, it just kicks me back to Windows with no error message.
System specs I know(my bro built my computer, and I don't know what all he used):
950 mHz AMD Duron processor
Radeon 7500 vid card
246 mb of RAM
I don't know what sound card I have, other than that it is built into my motherboard, it's a POS, and I *think* the name of the company that made the motherboard was Soyo.
I am a complete newbie to getting DOS games to run on XP, so I figured a forum would be the best and fastest place to get answers, and one of my buddies was helpful enough to supply the address of this site, so please do accept my deepest and most sincere apologies if I have not supplied enough information for you kind souls to help me remedy this problem.
