First post, by yokmismo
Hi
After buying a roland mt-32, i got a Roland SC-55MKII to complete the midi team (mt-32 & GM).
The problem is that, on one game if i connect the Midi out & midi in to the PC and to the sc-55, the digital voices get corrupted and continously cut off, this is strange because with the roland mt-32 the voices are ok...
Finally i found that if i disconnect the midi out on the sc-55, the digital voices suddenly are reproduced well!!, and the midi continues playing well too.
my questions are... ¿is necessary to plug the midi out on the roland and the pc for gaming or not?, ¿perhaps the SC-55MKII has the midi out failing?.
My soundcard is a SB16 (tried with 2 different)
Thanks in advance
Regards
