First post, by Totempole
Not sure if anyone can help me here, but I want to run Zone Raiders in 640x480 resolution on a Riva TNT2.
Obviously since it's not a UniVBE supported card, it doesn't load a supported driver. I've tried using the UniVBE modified drivers, but it still says "Video mode not available".
I have the same issue with Mortal Kombat Trilogy. It loads with the modified driver, but remains in 320x240 resolution.
The PC I want to run it on is only a Pentium 2, so too slow to run it in DOSBox. I'm running it Windows 98SE, but could also run it in MS-Dos Mode if required
I'm not sure if I'm using the modified driver properly, or if I must use it in conjunction with something else, so any advice would be much appreciated.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 1 of 3, by Davros
your tnt 2 isnt a m64 version is it ?
UniVBE and Riva TNT2 M64 totally incompatible? Alternatives?
ha edit: it's you 😁
how about freevbe ?
http://www.shawnhargreaves.com/freebe/index.html
Reply 2 of 3, by Totempole
Yes, it is 😀. But I now also have a TNT1 card as well. However, even if I use the TNT1 card I have the same issue. I'll definitely give FreeVBE a try and get back to you. Thanks.
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
