First post, by modelt26
I can get the program and start the program by typing 'start', an executable file. The program runs and gives a menu that should work. Each item in the menu is also exe files that take one to the family data. When trying any of these file, I get an error. It is obviously not linking to the data
Reply 1 of 3, by RacoonRider
Do you type
c:\whatever\start
or
cd whatever
start
It looks like you're running the program from wrong directory.
Reply 2 of 3, by modelt26
Thanks for this reply. My brother and I are running the same program. We seem to be doing the same thing. His works. Mine does not. Thought I had it going at one point but then all the daa went haywire. I will try some more and try starting from the beginning and see what happens. If I have no success I will repost. Thanks.
