First post, by rodimus80
Computer Specs:
Gateway G6-333
Pentium II: 333MHz
DOS 6.22
Audio: AWE64 Gold ISA
Video 1: mach64 PCI
Video 2: Voodoo 2
During Install of X-Wing CD Music is not heard but both sound effects are. I throw in TIE-Fighter CD with the same audio settings and everything there works. Suggestion?
TIE-Fighter
Sound Card: AWE32
Port: 220
IRQ: 5
DMA Channel: 1
Stereo Reverse: 0
UPDATE: Seems there are bigger problems. When starting the game I have no sound effects or music and it freezes upon clicking on the door after choosing pilot.
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S /W=C:\WINDOWS
REM ** C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
@ECHO OFF
C:\DRIVERS\MOUSE\CLOAKING.EXE
C:\DRIVERS\MOUSE\MOUSE.EXE
SET PATH=C:\DOS
GOTO %CONFIG%
:EMS
LH C:\DOS\MSCDEX.EXE /D:CDROM /E
GOTO END
:EMSNOCD
GOTO END
:XMS
GOTO END
:XMSNOCD
GOTO END
:MIN
GOTO END
:MINNOCD
GOTO END
:END
CONFIG.SYS
[COMMON]
DOS=HIGH,UMB
FILES=40
[menu]
menuitem=EMS, EMS memory with CD-ROM
menuitem=EMSNOCD, EMS memory without CD-ROM
menuitem=XMS, XMS memory with CD-ROM
menuitem=XMSNOCD, XMS memory without CD-ROM
menuitem=MIN, Minimal with CD-ROM
menuitem=MINNOCD, Minimal without CD-ROM
menudefault=EMS,30
[EMS]
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\CTCM\CTCM.EXE
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\CDROM\OAKCDROM.SYS /D:CDROM
[EMSNOCD]
[XMS]
DEVICEHIGH=C:\DRIVERS\CDROM\CDROMDRV.SYS /D:CDROM
[XMSNOCD]
[MIN]
[MINNOCD]
Reply 2 of 3, by badmojo
Hi! My only suggestion is to not use OAKCDROM with X-Wing - that's given me trouble in the past. Perhaps try the mitsumi driver, I know that works.
