First post, by EdmondDantes
- Member
Okay, so in this video I rant mostly about my Sidewinder (subject of a recent topic here), but near the end I also talk about an issue I've had running the game "The Lemmings Chronicles." After making that video, I tried using Dosbox to run it, and the game does work there, but it runs very choppily and pauses briefly every five seconds (Mazinkaiser is already vintage hardware, so Dosbox's slowdown effects are amplified), so I really need to run this game in a native environment to really enjoy it.
Here's the sitch:
When I first installed it, it gave me a runtime error. this it turned out I could get around by disabling the CPU Cache, so I install the game, and then... it tells me "Error: Can't find EMS driver!"
WHAT?! WHAT THE FLYING FLIP?!?! Now, I'm booting up with a config where I have Emm386 loaded and set to give me 8mb of RAM, so I know there's an EMS driver loading. So why isn't the game seeing it? Does it require a specific version of Emm386? Does it require a different EMS memory manager? Is it talking about something else entirely?
I tried reinstalling it, and this time letting it install with all-defaults, but that didn't help either. I've also tried adjusting the amount of memory, booting with different memory configurations, and even trying to run it in Windows 98 (which STILL gets the "can't find EMS driver" error).
So I'm turning to you for help, because I looked on Google, and I could find NOTHING on this issue. Apparently nobody else on the internet has ever encountered this problem.
So, what should I do?
Thanks in advance.
