First post, by Megadisk
I've been trying to play Zeliard in my Sega/IBM Teradrive pc. The Game loads fine from floppy , but the thing is that for some reason the gamepad I'm using some times its recognized, but other times don't, what could be the problem?. I've tried other gamepads, and the issue is the same.
I'm using a Sound Blaster Pro 2 CT1600 gameport with it, DOS 4.00. Of course the gamepads and gameport work ok with other games so no problem there.
I load the floppy, then I go to install which I'm prompted for the video and audio settings, then asks if I'm using a compatible IBM joystick (press yes), and according to the game manual during gameplay, to active the joystick is Ctrl+J ,but the gamepad works at times, and others don't. what's up with that?.
Any help is much appreciated.
