First post, by dario82
- Newbie
Hi, my MX518 (usb optical mouse) Work on Win98 SE with Setpoint driver but not in Dos mode. i need the driver for some games and norton commander.
which driver version should I download?
how do I install it?
Maybe Cutemouse works. http://cutemouse.sourceforge.net/
But i guess your bios has to support the the USB PS/2 conversion stuff.
Just use a PS/2 to USB adaptor and cutemouse. Works fine on my build 😀
wrote:Just use a PS/2 to USB adaptor and cutemouse. Works fine on my build 😀
i use this: right?
Yep. And cutemouse. Works just fine 😀
where you install this program? from windows or dos? which file should I start for install?
when I go to dos, start automatically?
i need help.
You have to add a line in your autoexec.bat.
Here's how I have mine set up:
"LH C:\DOS\Drivers\Mouse\CTM-21B4\BIN\CTM-EN.EXE"
Change the paths accordingly.
that's work!
thank you! 😊
