First post, by rodimus80
Game: Wolf (1994)(Sanctuary Woods Inc Us Gold)
Desktop:
Pentium MMX 133
604K RAM
Sound Blaster Pro 2 CT1600
DOS 6.22
When I load the WOLF.EXE I get the following error: Program too big to fit into memory
I tried also to load the SETUP.EXE but it just hangs in DOS.
My AUTOEXEC.BAT and CONFIG.SYS are as follows:
AUTOEXEC.BAT
SET SOUND=C:\SBPRO
SET BLASTER= A220 I5 D1 T4
SET MIDI=SYNTH:1 MAP:E
@ECHO OFF
C:\DRIVERS\MOUSE\CLOAKING.EXE
C:\DRIVERS\MOUSE\MOUSE.EXE
SET PATH=C:\DOS
GOTO %CONFIG%
:EMS
LH C:\DOS\MSCDEX.EXE /D:MYCDROM /E
GOTO END
:EMSNOCD
GOTO END
:XMS
GOTO END
:XMSNOCD
GOTO END
:MIN
GOTO END
:END
CONFIG.SYS
[COMMON]
DOS=HIGH,UMB
FILES=40
[menu]
menuitem=EMS, EMS memory with CD-ROM
menuitem=EMSNOCD, EMS memory without CD-ROM
menuitem=XMS, XMS memory with CD-ROM
menuitem=XMSNOCD, XMS memory without CD-ROM
menuitem=MIN, Minimal with CD-ROM
menuitem=MINNOCD, Minimal without CD-ROM
menudefault=EMS,30
[EMS]
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\CDROM\VIDE-CDD.SYS /D:CDROM
[EMSNOCD]
[XMS]
[XMSNOCD]
[MIN]
[MINNOCD]
Reply 1 of 3, by DosFreak
Every time I've seen that error it's because the files were corrupted.
http://blogs.msdn.com/b/oldnewthing/archive/2 … /30/519388.aspx
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 3, by tayyare
First of all, please check your available memory with "mem /c /p" command. If you have about 610-615KB conventional memory available, you most probably shouldn't have that problem. If not, you can still lower the conventional memory usage:
- I might be wrong but as far as I know, without loading EMM386.exe, "LH" or "devicehigh" commands will not work. They will just load their respective TSR's and drivers on conventional memory. So, even you want only XMS, you need to load emm386 with "NOEMS" command option.
- I also suggest you to use "ctmouse.exe" instead of your probably larger footprint mouse.exe /cloaking exe, and shsucdx.com instead of mscdex.exe.
- Try memmaker, it really works nicely.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
