First post, by samgallo@gfusa.net
DosBox works great,,,about 95% there. NewViews is an accounting software that uses the FKeys. Trouble is that when using it in DosBox the windows FKeys are superior and will not let the DosBox FKeys work. NewViews uses a KeyLogger for its FKeys so using the DosBox key logger isn't going to work. Illustration, F4 in NewViews is /de. Is there a way that DosBox can disable Windows FKeys while DosBox is working?
