First post, by krovlar
I have a Windows 98SE gaming PC:
Intel Pentium III 866 MHz processor
512MB PC133 SDRAM memory, (2 x 256MB modules)
ATI Rage 128 Pro (16MB) graphics/video controller card (AGP 4x)
SoundBlaster PCI128 model "CT4700" audio controller card (PCI)
Which is great for games like X-Com Apocalypse and other early windows 95-98 games, but it is terrible for Dos games. X-Com UFO Defense runs too fast(X-Com UFO Defense Gold windows version plays music but is just a black screen), Wing Commander is on super fast forward, the sound card isn't compatible with a lot of the older dos games as Soundblaster doesn't work, but Soundblaster pro seems to.
Anyway, what I want to do is install DosBox on this machine so that I can play the old DOS games on my vintage machine with the lower resolution monitor. Does anyone know a way to do this, or a DosBox unofficial port or something? Thanks.
Reply 1 of 12, by DosFreak
The official version of DOSBox installs and works fine on Windows 95+.
Do not play DOS games in DOSBox that are newer than 1995 since that processor is too slow.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 12, by krovlar
Thanks! For some reasons I thought that DosBox was only WinXP and beyond. I don't plan to use DOSBox for anything above 1995 since I can use regular DOS for most everything at that point, it's just the early stuff that I am having trouble with. For the most part. Thanks for the help!
Reply 3 of 12, by DosFreak
You'll see alot of the unofficial ports that won't work on older Windows operating systems because they were compiled with newer versions of Visual Studio but since the beginning and up to today all versions of Windows starting at 95/NT4 are supported.
Reply 4 of 12, by krovlar
Again thanks. I was able to install my X-Com UFO Defnese cd's (I got the Apocalypse edition with the original two games included) as well as Wing Commander and got them running really well. Sadly I am still using emulation to game on my specifically retro built gaming PC, which is kinda funny.
Reply 5 of 12, by Jorpho
Didn't someone come up with a fix for those already? They are immensely popular games and someone must have tinkered with them by now.
As for the sound card, do you have the DOS drivers (i.e. sbinit.com) ?
Reply 6 of 12, by krovlar
I have one set of drivers, but I guess there is an issue with the particular card I have, CT4700, where there are two sets of drivers. One from SoundBlaster/Creative Labs, and one from Ensoniq I believe. As far as tinkering with fixes, I haven't read anything about it. There is UFOExtender, but I don't think that is exactly what you are talking about.
Reply 7 of 12, by Jorpho
Creative bought Ensoniq and re-released one of Ensoniq's cards. I don't think the drivers are interchangable.
If nothing else, Open XCOM finally came out recently.
Reply 8 of 12, by krovlar
Thanks for the heads up on OpenXcom. I'm going to see if it installs on my Pentium 3 machine. If it works like it says it does I'll be very excited to see Terror from the Deep come from them eventually. Hopefully.
Reply 9 of 12, by mrrhq
I know your pain. That's the great thing about DOSBox, is the control you can have over everything like sound cards, graphics and CPU speed.
My suggestion is to just use your old PC for Windows 95/98 games only, and play your dos games with DOSBox on a faster PC running anything from Windows/Mac/Linux.
Why? Well any emulator is going to require the host PC to give up a little more resources so the bytecode translation stuff works faster. That's the common drawback of emulation. You think your DOS games may run fast, but some top DOS titles will probably run a lot slower on your Win98 box if you use DOSBox on there, I guarantee it. Although.... the thing is, you could probably try using core=dynamic for everything if you ahve a Pentium 1 and play every dos game at the speed you want without running into any crashes. That might actually not be a bad idea.
Dedicated Debian Dude
Reply 12 of 12, by krovlar
It's a smaller flat panel monitor with a max resolution of 1024x768. Old games look much better on it than they do on my 30 inch 1080p monitor. As to hooking it up to my newer PC, it's do-able but that means unplugging it from my retro PC, unplugging my newPC monitor, plugging in the retro one, playing the game, then swapping them all back and re-arranging the icons on my desktop after everything went to 1024x768 and then back to 1080p. It's just easier to use the older PC if its not having any problems playing the game.
