First post, by Thandor
- Member
One thing I have been tinkering with years ago, recently popped up in my mind: I want to "pause" or fix the real-time clock in DOS to a certain date/time. In the past I wrote a simple TSR in Turbo Pascal which configured a given date over and over as fast as it could. This worked but was not stable. In order to attack the problem at another level I tried loading up the DOSBox source code but after getting a gazillion errors (I'm probably cursed in importing source code in VC++) I dropped this idea and thought about asking this forum:
Who knows about a way or DOS-program that is able to fix/lock the date/time? 😀
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
