First post, by jheronimus
Hi, all.
I have a system running MS-DOS 6.22. Here are the specs:
486DX2 66 MHz;
12 MB RAM (4 MB onboard + 8 MB in one SIMM);
Cirrus Logic CL-GD5402 512 KB;
ESS ES1868F Audio Drive sound card;
Quantum Fireball EL2.5A 2,5 GB IDE hard disk.
Note: this is an all-in-one Compaq Presario 433 machine.
Whenever I try to run DOOM2 1.666 I get various errors.
At first I mostly got this:
2.16 MiB
I tried upgrading it to DOS4G 2.01 — got the same error. Then I replaced it with DOS32A. Now I usually don't get any "divide by zero" errors, but I get one of the two cases:
- I get a single "beep" out of the speakers and then a blank screen. The system freezes and needs to be powered off (doesn't react to Ctrl+Alt+Delete);
- I see the logo screen, but right before the demo is supposed to run, the image doubles (can't catch it on the camera, sorry) and then I get a blank screen and everything freezes.
Edit: Oops, sorry. Looks like it's DOS4G 2.01 that doesn't result in divide by zero error, not DOS32A.
I've been playing a lot of different games on this machine, including XCOM, Lands of Lore, Ultima Underworld/Ultima 7, Eye of the Beholder and many others.
Edit: Oh, forgot to mention I also can't run Wolfenstein. I'm just stuck at this screen after installation:
1.38 MiB
What else can I do to run DOOM? Thanks!
MR BIOS catalog
Unicore catalog
Reply 1 of 38, by Great Hierophant
I would suggest that you check your sound card settings, otherwise make sure you can run these games in DOSBox to rule out damage to your files.
Reply 2 of 38, by kixs
Try running with clean DOS start without any drivers (press F5 at boot).
Otherwise my guess is something with memory. Does Speedsys work?
Reply 3 of 38, by jheronimus
Running after F5 results in another Divide by zero.
Speedsys doesn't work, it gives me this:
941.16 KiB
"Determining system contents... CPU clock/ERROR: Divide overflow."
MR BIOS catalog
Unicore catalog
Reply 4 of 38, by jheronimus
DOOM works under DOSBOX. Tried disabling all sound in the setup utility — same result.
MR BIOS catalog
Unicore catalog
Reply 5 of 38, by jheronimus
Here is the image corruption freeze I've mentioned.
    1.98 MiB
MR BIOS catalog
Unicore catalog
Reply 6 of 38, by clueless1
Have you physically pulled the sound card out and tried? Make sure any sound card settings are REM'd out of your autoexec and config files. Speedsys does not like EMM386. Do you have an add-in graphics card you can try? Any BIOS settings you've toggled?
Reply 7 of 38, by jheronimus
Do you mean, to run DOOM2 or to run speedsys?
I actually tried both rem-ing everything and just running under F5. Originally speedsys says if there is EMM386 or anything else it doesn't like, it didn't say anything with rem-ed files and after F5. But it didn't work, too.
MR BIOS catalog
Unicore catalog
Reply 8 of 38, by clueless1
Either. Since neither Doom2 nor Speedsys are working, I'm just wondering if there is a hardware conflict that could be determined quickly by running without the sound card installed.
Reply 9 of 38, by jheronimus
Tried that: removed the sound card, booted under F5. Speedsys doesn't work. DOOM2 allows me to a bit further (I can see the demo behind the menu) before giving me the same glitch and freezing.
MR BIOS catalog
Unicore catalog
Reply 10 of 38, by clueless1
Are there any BIOS settings with the word "Shadow" in it that you can toggle between enabled and disabled? Different BIOSes refer to the setting differently, so it might be called BIOS Shadow, Shadow Memory, Shadow RAM, etc. Try toggling them one at a time between tests to see if any of them might fix the issue.
Reply 11 of 38, by jheronimus
No, there isn't.
MR BIOS catalog
Unicore catalog
Reply 12 of 38, by clueless1
Darn it. I have a DOS game (US Navy Fighters) that uses the Phar Lap DOS extender. This is incompatible with some motherboards unless you disable BIOS Shadowing. On my Packard Bell Multimedia C110, this game does not work and I have no BIOS settings to adjust, so I'm out of luck. On my other DOS machine, it does work and I don't even have to mess with BIOS settings. I don't know if this is what's going on with you, but your issue made me think of my own, hence why I brought it up. Hopefully someone else can give you some more things to try! Best of luck, mate.
Reply 13 of 38, by jheronimus
Also, correct me if I'm wrong. A lot of you seem to assume that there is something wrong with my RAM, and so, less resource-hungry games are fine, while DOOM hits some kind of a damaged segment (that older games don't reach) in my RAM and crashes. I've just tried playing Elder Scrolls: Arena and had no issues — isn't that a resource-hungry game as well?
Also, I have 30 games installed right now. None of them had any issues with my sound or RAM. Could it be that DOS4GW error was unrelated (since it was largely resolved with an update) and it's something about ID's engines? Maybe it has issues with my integrated Cirrus Logic card? How do I check for that?
MR BIOS catalog
Unicore catalog
Reply 14 of 38, by jheronimus
Well, Wolfenstein doesn't use an extender, right? I mean, the only thing these two games have in common is that they are both made by Id?
MR BIOS catalog
Unicore catalog
Reply 15 of 38, by clueless1
I don't suspect RAM. The fact that so many other games work led me to believe it was an issue more along the lines of my previous post (id software's DOS extender issue with your BIOS). If that is the case, you may not be able to do anything about it. I suppose it is possible that there are other BIOS versions to try that might allow you to change this setting, but it may not be worth the risk for two games. Do you have any way to install any other video card besides the onboard Cirrus Logic? If you can disable onboard graphics and use another graphics card, that will at least eliminate that possibility.
Reply 16 of 38, by jheronimus
No, unfortunately, this system only has ISA slots, and I don't have any ISA videocards. And since it's an all-in-one it doesn't make sense to use anything but an integrated card (I'd have to use an external screen as well). BIOS isn't flashable to my knowledge, it's one of those Compaq F10 setups that are fairly limited.
Yeah, I know it's a system with a lot of limitations, but I've seen people on YouTube playing Doom on this machine 😀
MR BIOS catalog
Unicore catalog
Reply 17 of 38, by jheronimus
OK, I accidentaly tried running Wolfenstein under F5 and it worked. Looks like it did have issues with my sound card. DOOM2 doesn't run in this mode, though.
MR BIOS catalog
Unicore catalog
Reply 18 of 38, by Azarien
I just checked the source code. Wolfenstein 3D uses EMS and XMS memory if available, but no DOS extender.
It seems there is a kind of hardware problem or conflict in your PC, and that's not specific to DOS4GW.
Could you post your CONFIG.SYS and AUTOEXEC.BAT?
Reply 19 of 38, by jheronimus
Here you go, thanks!
autoexec.bat
LH /L:0;2,45456 /S C:\DOS\SMARTDRV.EXE /X
LH C:\APPS\DOSKEY.COM -I
@ECHO OFF
PROMPT $p$g
PATH C:\DOS;C:\APPS\PHOENIX
PATH C:\APPS
PATH C:\NC;%PATH%
SET TEMP=C:\DOS
LH /L:0;1,3104 /S C:\APPS\CTMOUSE.EXE /3
@SET PHX=C:\APPS\PHOENIX
C:\APPS\ESS\ESSCFG.EXE /A:220 /I:5 /D:1 /E:3 /B:330 /J:E
C:\APPS\ESS\ESSVOL.EXE /V:6 /L:0 /W:7 /M:7 /C:7 /S:7 /A:0 /P:0
SET BLASTER=A200 I5 D1 P330 T4
config.sys
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM HIGHSCAN I=B000-B7FF
BUFFERS=15,0
FILES=40
DOS=HIGH,UMB
LASTDRIVE=E
FCBS=4,0
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DOS=HIGH
MR BIOS catalog
Unicore catalog
