First post, by BSF2015
Is there a tutorial on manual or magazine, to make a cracktro for MS DOS??
And also, how to train a game??
Can you please help me??
Reply 1 of 3, by Jorpho
You do it in mostly the same way that you would make a PAC-MAN game in DOS.
How to make a Pacman game on MS-DOS??
If it all seems overwhelmingly complicated, that's because it is. It's like writing a novel, or carving a sculpture. The closest thing you can get to a "tutorial on manual or magazine" is an introductory programming course.
If you want to "train a game", you should probably just use a utility like Gamewiz32 or Infinity Machine.
Reply 2 of 3, by Ampera
The search term is x86 ASM. That's what people used to use to crack games, and that's what a lot of games were programmed in. That, or C, which is slightly easier, but with SLIGHT overhead.
Reply 3 of 3, by keenmaster486
@BSF2015, most of the information you need is easily found just searching around on the internet.
But for you I would recommend getting Microsoft QuickBasic 4.5 and getting really good at that, and only then should you think about moving to something like C or ASM.
World's foremost 486 enjoyer.
