First post, by appollo147
I downloaded the full cd rip of Orion Burger from HOTU and when I try to run the setup.exe in either DOSBox or VDMSound I get this error "Programmers Note:VESA Driver Not Found,please install one and re-install the game." Im running on XP with a Nvidia GEforce4 MX 420 video card.I even tried loading the setup through XP without either DOSBox or VDMSound and it just opened and closed back out again.Any help you can give me will be greatly appreciated.Thank you in advance.
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Re: VDMSound - isn't there a checkbox somewhere in the VDMSound LaunchPad that enables VESA support?
_________________
Reply 2 of 3, by eL_PuSHeR
Rank Moderator
Moderator
That's misleading. It should read: "run in fullscreen"
It does nothing to do with VESA. 😎
And regarding Orion Burger; the game is probably looking for a propietary VESA driver such as Scitech's Univesa, UniVBE or display doctor. Try running UniVBE before starting the game (preferably inside a batch file) or vbeplus (another VESA driver incarnation).
Reply 3 of 3, by DosFreak
Try running the program in a full-screen command prompt, sometimes when running DOS programs that require VESA support in a window, windows will not switch to full screen automagically.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
