First post, by toschulz
It looks like I have my USB T.16000M working with Bret Johnson's USB DOS Drivers on MS-DOS 6.22. My joystick shows up fine when I run "Thrust D" at port 201h, but no matter what I do X-wing and Tie Fighter will not see the Joystick. Has anyone had luck getting a USB joystick to work with the USB drivers or are they just not compatible?
