First post, by Parni
Hi,
I have been browsing through the net that is there a way how to get more than four players through IPX in Doom or Doom2 but havent found a solution yet, so I decided to ask also here. Any solutions to increase the multiplayer amount?
Reply 1 of 4, by doshea
I'm not an expert in these things but I had a look and found a source port which supports up to 32 players and can be compiled with IPX support (it uses TCP/IP by default): http://doomlegacy.sourceforge.net/docs/legacy.html It looks significantly different from the original DOOM though.
Reply 3 of 4, by dr_st
One thing to keep in mind is that original DOOM levels only have starts for players 1-4 in coop mode. You can have more than 4 deathmatch starts, though, so there, the limit may be lifted by a source-port.
Reply 4 of 4, by MasterO
Parni wrote on 2022-01-10, 09:28:
Hi,
As far as I know, there is not.
Your best bet is multiplayer Doom on modern source ports, such as:
https://odamex.net/
https://www.zdaemon.org/
https://zandronum.com/
