First post, by silverstoned
Hi all,
After a while I finally got Alien Trilogy working on dosbox (im using D-Fend as a frontend, btw).
However it moves too fast the xenos are EVEN FASTER then in the movies 🤣. I understand this is something old games did when the game speed was tied to the proc. power. Is there something I can do to fix this?
Secondly, I set the game to be windowed at a set resolution. However after the initial DOS commands the game runs at like 640x480 instead of the 1280x1024 I set it to. Can anyone help?
Thanks
Reply 2 of 5, by zirkoni
silverstoned wrote on 2022-06-26, 00:40:
...the game speed was tied to the proc. power. Is there something I can do to fix this?
Yes, change the emulated CPU cycles in DOSBox:
cycles 30000
https://youtube.com/@zirkoni42
Reply 3 of 5, by buckeye
I've read on this forum many times that this game is a challenge to run even on "real" hardware. Can't offer any help but I plan on
trying to get it to run using D-Fend also. Please post you're findings here if you don't mind.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 4 of 5, by silverstoned
zirkoni wrote on 2022-07-05, 06:23:
cycles 30000
that stops the game loading, period.
Reply 5 of 5, by gaffa2002
You can try increasing the cycle count by pressing f12 until the game runs at an acceptable speed. Alien Trilogy is a very buggy game even on actual hardware, so don't worry as dosbox is providing you the real experience 😁
LO-RES, HI-FUN
My DOS/ Win98 PC specs
EP-7KXA Motherboard
Athlon Thunderbird 750mhz
256Mb PC100 RAM
Geforce 4 MX440 64MB AGP (128 bit)
Sound Blaster AWE 64 CT4500 (ISA)
32GB HDD
