First post, by cmw
Hi!
I installed Buried in Time today and it runs quite fine under WinXP (Comp Mode). The only problem is that many animations are off-center. I found a corresponding error description and solution here: http://presto.tommyyune.com/presto/journeyman … pport.html#PC14
As you can see, it tells me to modify the mci video for windows driver. Well... how can that be done? 😀
Or does anyone know another solution?
best regards
edit1: I temporarily by-passed the problem by playing on win95 on virtual pc, videos work fine there but overall performance is only about at 80%, so it's playable, but not fully fluent. So still, a solution for the offset video in winxp would be welcomed .)
Reply 1 of 3, by Davros
it appears he missed out a few steps
open control panel
open sounds and audio devices
click hardware tab
highlight mciavi32.dll
click properties
click settings
make sure window + original size are selected
Reply 2 of 3, by cmw
Thank you for that, but there is still a problem: mciavi32.dll is not listed there. Now that's strange for sure (the dll is in my system32 directory).
Maybe any thoughts on how I can get it there?
Reply 3 of 3, by Davros
open system.ini
look for the following section
[mci]
MPEGVideo=mciqtz.drv
MPEGVideo2=mciqtz.drv
avivideo=mciavi32.dll
cdaudio=mcicda.dll
sequencer=mciseq.dll
make sure the mciavi32.dll line is there
ps: backup your system ini before you do anything
