Winquake 1280x1024
First post, by Meeehr
Hello
When i start the GLQuake exe, with this Parameter:
-width 1280 -height 1024 -bpp32
It crash on Start.
Have you a sollution for me ?
Reply 1 of 4, by DosFreak
Assuming this is a legit question, which one are you trying to run and why would you use glquake in 2023 (or ever....)?
If you want to use glquake instead of quakespasm or tyrquake (both of which work in 95+) then you'll likely need to hexedit the executable, or use a graphics wrapper or configure the GPU to limit the extensions. This is assuming that you are using a GPU that is much newer than the game.
Make your games work offline
Reply 2 of 4, by Meeehr
OK
I have Collected many many Old Hardware.
GL Quake i only can make 640x480, i play Windowed with bpp32.
Never Use a Wrapper or Emulator
Reply 3 of 4, by Flashback
If that's not a typo, add a space between -bpp and 32.
Hope that helps.
Reply 4 of 4, by Meeehr
Thanks
Bud work not, GLquake only 640x480 32 Bpp Window can make.
Or the winquake in 1280x1024
My Hardware:
Athlon 3600
5000
2x 6000
FX 4100
Pentium E5400
Core To Duo E7300
Core To Duo E7500
Core To Duo E8600
Core To Quad Q9500
Austausch Ram und Kompatibel Listen für jedes Board vorhanden
Biostar GF8100 M2 + TE
Asus M2A-VM
Asus M2N-68-AM Plus
Asus M5A-78L-M-LX-V2
Gigabyte G31M-ES2L
Gigabyte G31M-S2L
Gigabyte G33M-DS2R
Gigabyte G41M-ES2L
4x 5870
1x 5850
2x 4850
5x 6670
1x 660 GTX
2x 570 GTX
1x 560 GTX
4x 8800 GT
Werks Treiber CD ISOs
NEC Multisync LCD 1760NX
2x 1970NX
Fujitsu Siemens Szenic View P 19-2
Dell Ultrasharp 1908FP
Dell Ultrasharp 1908FPT
4x Saitek P1500
1x P750
2x PS 2700
1x P2600
XP 32
Vista 64
Win7 32
