First post, by Procyon
The reason I want the Windows version of EF2000 is because I remember it to have a smoother framerate than the dos version and also with a little luck I might be able to pump up the resolution with the use of dgVoodoo 2.
After I managed to succesfully install it using the InstallShield 3 method described here I run into the following problem when running _SUPERW.EXE.
I get a small splash screen and a dialog box prompting me it can't find data and the CD (which is in the drive by the way).
I already tried a number of methods, like setting Windows 95/98 compatibility for the .exe and I tried hooking it up with DxWnd but none have been succesful.
So if anyone has any ideas or even succesfully managed to run it I be grateful.
Reply 1 of 1, by Procyon
L O L, while writing this I think I solved it.
I have to run setup32.exe again and then it asks you to run the game.
