First post, by ReignerDeustcher
I'm running this game with dgvodoo2 and the actual gameplay looks fine but the menues look like weirdly smeared:
Reply 1 of 3, by BEEN_Nath_58
ReignerDeustcher wrote on 2024-01-09, 01:27:
Looks like the game is being integer scaled
Reply 2 of 3, by ReignerDeustcher
BEEN_Nath_58 wrote on 2024-01-09, 04:54:
weird, i don't have that enabled in any place
Reply 3 of 3, by BEEN_Nath_58
ReignerDeustcher wrote on 2024-01-09, 19:04:
Either it is enabled in dgVoodoo2 or if not, in driver. If not in both, there's a probability dgVoodoo2 is doing it itself. The only reason I can assume for it to scale on its own is ONLY IF the game uses a resolution not enumerated by your driver. A good way to check is to test if the game is without dgVoodoo2: fullscreen (with bilinear filtering ON) or fullscreen (with integer scaling ON) or not properly fullscreen. Only in the first case, it should mean the resolution required by the game is present in the driver.
If neither is the case, it would be better to ask in the dgVoodoo2 threads instead.
