First post, by Froakiein2023
On Windows 11 (the 64-bit version), I've installed Motocross Madness 1 and setup dgVoodoo 2.82.5. When I started Motocross Madness 1, the game plays the intro fine and then goes into the main menu.
However, whenever I attempt to start a race or go into the Garage, the game always crashes to the desktop. I've also tried changing the compatibility settings and changing some settings in dgVoodoo, but that still didn't solve the issue.
Does anyone have any suggestions about how to fix the problem?
My Laptop Specs:
Windows 11 64-bit
AMD Ryzen 7 5700U with Radeon Graphics 1.80 GHz
16.0 GB RAM installed
Reply 1 of 2, by BEEN_Nath_58
Froakiein2023 wrote on 2024-05-04, 16:49:
On Windows 11 (the 64-bit version), I've installed Motocross Madness 1 and setup dgVoodoo 2.82.5. When I started Motocross Madne […]
My Laptop Specs:
Windows 11 64-bit
I tried it with and without dgVoodoo2 and it works. If its a problem with dgVoodoo2, you should ask in their thread
Reply 2 of 2, by Froakiein2023
Actually, I've figured out the problem. I was using Creative ALchemy Universal in Motocross Madness and it was causing the crashing problem, so I removed Creative ALchemy-related files from the Motocross Madness directory.
