First post, by miller11568
How can I remove the Juiced error "Juiced requires virtual memory to be enabled" via hex editing the executable instead of using the compatibility mode or applying the official patch?
Reply 1 of 12, by BEEN_Nath_58
Why do you want every solution through "hex-editing"?
Reply 2 of 12, by miller11568
BEEN_Nath_58 wrote on 2024-05-19, 17:21:
Because I'm a PC game hacker. I have HxD and I'm interested for hex editing executables to remove errors.
Reply 3 of 12, by myne
You're a game hacker when you are the one creating the hex edits from scratch.
Enjoy learning though
I built:
Reply 4 of 12, by miller11568
myne wrote on 2024-05-20, 05:54:
Which offset or address?
Reply 6 of 12, by miller11568
myne wrote on 2024-05-20, 08:54:
0xD00D
That's the wrong offset or address for removing "Juiced requires virtual memory to be enabled". Can you give me the proper offset?
Reply 8 of 12, by miller11568
When I try to do a test drive, Juiced crashes. Can someone help me fix this problem?
Reply 9 of 12, by myne
https://medium.com/ax1al/introduction-to-windbg-1177487c77a4
Good luck
I built:
Reply 11 of 12, by miller11568
No one has found a file offset to bypass the message "Juiced requires virtual memory to be enabled"?
Reply 12 of 12, by teleguy
miller11568 wrote on 2025-02-27, 17:20:
The link I posted already contains the answer.
	char memFix[] =
0xEB, 0x20
// Fix "Juiced requires virtual memory to be enabled"
injector::MakeNOP(0x0059BE39, 2, true);
injector::WriteMemoryRaw(0x0059BE40, memFix, sizeof(memFix), true);
