First post, by Zup
I was trying to run "The House of the Dead" in a friend's computer (more precisely, his son's computer). It was an spanish edition from FX Interactive.
The problem is that the game shows black boxes around most textures (as if it were unable to render transparency). It shows black boxes around trees, damage, gunsight... everything.
I've tried it using default mode (2D very ugly mode) and direct 3d (slightly less ugly mode), but it remains the same. Actually, in d3d damage transparency is "almost" shown (50% transparency where it should be 100% transparency).
The game runs in an Windows XP, using a Nvidia 6600 and DirectX 9.
Also, i don't know if it can be run at highers resolutions than 640x480.
I'm selling some stuff!
Reply 1 of 8, by leileilol
Zup wrote:
using a Nvidia 6600
This is your problem. You are playing on a card that nvidia intends to cripple support for legacy apps and games on. They do not want you to play HOTD, they want you to play Crysis/Prince of Persia/etc.
I don't know if HOTD supports glide mode though, probably not
Reply 3 of 8, by olemogamer
That's not true. I play HOTD on two different XP pc's and have no problems with either one. One of them has a 7950GT 512 mb card running the May 08 drivers. I didn't have any problems using older drivers either.
Since I don't have this problem, I really can't help you. But I wanted to make clear it's not because nvidia cards don't work with older apps.
Reply 4 of 8, by Zup
I've downloaded it from an abandonware site and it works in my computer (Nv 7900GS with v.163, XP SP3, Dx9,). Crap!
Definitely, I'm clueless now...
Reply 5 of 8, by Devil Master
I have the same problem with Sega Rally 2 (the regular 2-disc version that I run on Windows XP): most textures are surrounded by black boxes instead of transparent areas.
I tried to download a "ripped" version and install it, but if I try to run that, a message comes up saying it does not support NT-based operating systems, so I deleted it.
Reply 6 of 8, by filipetolhuizen
Try updating your directx and using different drivers.
Reply 7 of 8, by VirtuaIceMan
This is odd. I don't have either problem in either game, but I do with Sega's Marine Fishing - the Japanese demo you can see properly underwater (and it has some sort of network mode!) but the UK Empire Interactive version fog obscures everything...
Sega PC games have always been a bit "special"...
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 8 of 8, by filipetolhuizen
Yes, I have a problem with Daytona USA. I have to disable hardware acceleration for the game to simply run (or enable "ForceDirectDrawEmulation" in ACT 5.0 for Daytona.exe). It wasn't necessary back when I had a Geforce 6800.
