HunterZ wrote:You may have trouble with Windows Update, which is bad because Win9x will get infected with all sorts of crap if you plug it into the Internet and don't get it fully patched ASAP.
I've just recently installed Win98se on a P-II breadboarded rig, using an Intel SE440BX. I have the 2004 all-Windows Security Rollup CD that I run almost all installs through before taking a new install out into the Never-Never land of the 'Net. Microsoft's Windows Updates still works, if you use IE 5.5 or 6.0. Of course, I had already installed both SpyBot S&D and Spyware Blaster, as well as Avast!
I don't know any more exactly which number goes with which Win98 version, but an OEM expects a number within certain ranges, as does the Upgrade. The Full Install has its own range it expects numbers from. I have a text file with my three Win95 numbers, four Win98 numbers (only one the pre-SE), four W2K, six WinXP, Win7 Beta, Office 2000, etc.
If I've dione recent installs, I remember which numbers the discs will want, but that sort of thing doesn't remain in memory long, so sometimes I must try a couple before i hit the right one.
