First post, by Svenne
I got NFS SE for christmas by my parents. Problem is it won't run on Windows 98. When I run the installer I get an error message about INFSW.EXE wich I cannot switch to. After closing it I get two "illegal exception" messages about the same program.
INFSW orsakade ett ogiltigt sidfel i
modul <okänd> på adress 0000:0b75fc5d.
Registrerar:
EAX=bff87fe9 CS=0167 EIP=0b75fc5d EFLGS=00010246
EBX=bff87fe9 SS=016f ESP=005c00e0 EBP=005c0100
ECX=005c0184 DS=016f ESI=8196ffe0 FS=41a7
EDX=bff76855 ES=016f EDI=005c0278 GS=0000
Byte på CS:EIP:
Stackdump:
bff76849 005c0278 bff87fe9 005c01ac 005c0184 005c0564 bff76855 bff87fe9 005c0194 bff87fe9 005c0278 bff87fe9 005c01ac 005c0184 0b75fc5d 005c02ec
modul INFSW.EXE på adress 0167:0041d285.
Registrerar:
EAX=00000000 CS=0167 EIP=0041d285 EFLGS=00010206
EBX=004816e8 SS=016f ESP=005cf208 EBP=005cf3e0
ECX=00000000 DS=016f ESI=000000ac FS=4057
EDX=005cf2bc ES=016f EDI=00000000 GS=0000
Byte på CS:EIP:
8b 08 50 ff 51 2c 83 3d f0 d6 43 00 00 74 0d 68
Stackdump:
005cf2bc 005cf210 000000ac 00000000 00000000 2bc60000 2bc605c8 405717b7 047c0000 824e17b7 17b79f4a 000205c8 00000502 005cf270 81909050 8196c0bc
System specs:
* Intel Pentium II 400 MHz.
* Acer V66XA motherboard.
* ATi Rage Pro Turbo 4mb graphics.
* 256 mb RAM (128x2).
* Windows 98 SE.
* KernelEx 4.5 RC5.
* Revolutions Pack 9.7.0.
* DirectX 9.0c.
Suggestions please?
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 2 of 5, by Svenne
It didn't find anything, but thanks anyway.
I suspect the problem could be caused by some of the add-on components RP9 or K-Ex 4.5, because Borland Resource Workshop 4.5 doesn't work either.
Reply 3 of 5, by doomer
I remember having problems with Need for Speed SE on Windows 98 SE back in the old days. The only way I could make it work was to freshly install Windows 98 SE and not update DirectX. If I updated DirectX I was getting the same illegal exception as you.
Reply 4 of 5, by zenith2009
I play NFS SE on my Virtual Machine (Host is XP Pro, Guest is Win98SE) without any issue. Software rendering is enough for this game + PCI64 sounblaster emulation.
Works like charm.
Reply 5 of 5, by Rekrul
I don't remember if I got the same error messages or not, but the last time I tried to install NFS:SE under W98, I also had problems. The solution, as suggested by user "5u3" was to right-click on the Desktop, select Properties, then click on the Settings tab, click the Advanced button, then click the Performance tab and lower the Hardware Acceleration slider by 1-2 notches. After doing this, both the installer and the game worked for me.
If this works, remember to turn the acceleration back up when you're done playing.
I hope this helps.
